Head gasket
PostPost by: Robbie693 » Tue Apr 01, 2008 2:08 pm
I fitted the new head gasket yesterday and noticed that it wasn't exactly the same as the old one.
The old gasket had small holes for the waterways but the new one has holes the same size as the passages in the head/block.
I got the gasket in a set from Paul Matty's, will the bigger holes make any difference?
Robbie
Robbie693
PostPost by: steveww » Tue Apr 01, 2008 5:26 pm
Better water flow to the thus better cooling???
The last one I fitted (from QED) was like that. So far so good.
steveww
PostPost by: Robbie693 » Wed Apr 02, 2008 8:56 am
Thanks Steve,
That's ok then - I was concerned I'd got the wrong one.
Robbie
Robbie693
PostPost by: denicholls2 » Wed Apr 02, 2008 1:26 pm
My recollection is that you do, indeed, have the "wrong one". The smaller passages in the "correct" one are used to balance heat transfer across the cooling areas of the head.
Possibly a minor issue for anything short of severe operation, but as I recall the thread, the restricted one is the improved model.
denicholls2
PostPost by: Robbie693 » Wed Apr 02, 2008 1:36 pm
Bugger...
As the engine is back together I suppose I'll have to see what happens - what problems should I look for that could be caused by this?
Robbie693
PostPost by: b-havers » Wed Apr 02, 2008 2:39 pm
Interesting to follow this discussion, as I will fit a new headgasket myself, in a couple of weeks...
Bjorn-Anders, Norway
'95 Caterham Seven Roadsport
'02 Elise Supercharged
ex Europa S2
ex Elan +2S 130
ex Esprit Turbo
ex Caterham SS
Life is too short to drive boring cars
b-havers
PostPost by: Robbie693 » Thu Apr 03, 2008 11:04 am
Well I called Paul Matty and they rekon the gaskets they have in stock have the small holes and are somewhat at a loss to explain why mine is different..
They asked me to bring it in and when I told them I had already fitted it said "what did you do that for?"
Exactly :oops:
So I'm going to take the old one in and compare. Will report back when I know what's going on
Robbie693
