Heaters
Hi all
I've just returned from getting my Sprint through its annual MOT. (Handbrake was a problem as usual but just made it)
Having now sorted cooling with electronic water pump system I think the time has come to sort some human temperature problems - I tend to go out in the dry only but I always have the roof off even in winter and although today wasn't desperately cold, my heater is pathetic so I froze. To increase the body temperature, I ended up flooring the car wherever I could and used some adrenaline (great fun but deals with the effect not the cause).
I really want to sort the heater problem. The matrix is refurbished and I know there is a flow going to it because with the pump running the pipes are warm (not hot) all the way along. The main cooling system has a very good flow.
The bore of the matrix and pipes is 1/2". Is this normal?
I am considring fitting a small elec pump just for the heater but i wonder if the problem is with the capacity of the matrix. There is certainly no problem with airflow and the fan is really good.
Any ideas gratefully received.
Gavin
Gavin
gav - Fourth Gear
Gavin
Great idea?Fit a small electric pump and wire it to the Heater fan switch?
Look forward to any ideas....
John![Wink :wink:](https://lotuselan.net/forums/images/smilies/icon_wink.gif)
Gav
If your heater hoses are only getting warm then that is poor flow.
There has been some discussion in the past about electric water pumps affecting the heater circuit.
Electric water pumps usually call for the removal of the thermostat.
This I believe reduces the flow to the heater.
Clive
Clive
1972 Elan Sprint FHC
- cliveyboy
Matthew
The engine is running around 85 degrees.
Clive
I wondered about this when I removed the thermostat hence my thought about a lightweight ancillary pump just for the heater. If this is the answer, does anyone know of such a pump (other than the Davies Craig solution which is a little dear)
Is the 1/2" bore of the heater system typical?
Gavin
Clive
Gavin
gav - Fourth Gear
Gavin
Here is a little trick to try.
Take your thermostat and remove the central part (the bit that opens and closes) just leaving the outer brass body.
Refit the thermostat.
This should give you some restriction but still allow the new pump to circulate water.
See if the heater gets hotter but just watch your temp gauge.
1/2" bore is standard size for Elan heater hoses.
Clive
Clive
- cliveyboy
Gavin,
An ancillary pump for the heater was fitted to the old style Ford galxay MPV and costs aroung GBP ?60 new.
I Actually have one in the garage I used for a short while on another project (turned out the matrix was clogged), make ma an offfer? or I could shove it on ebay.
Kevin
Kevin
- kstrutt11
