carbon removal
Whats the safest way to remove carbon fron cylinder head and pistons
Regards John 1969S4DHC
- triumphelan
soak the head face in redex overnight first if you are going to wire brush. Most engine reconditioners have a cold dip that will remove the carbon and they will dunk your bits if you speak to them nicely. Any rubber like the breather grommet will have to be removed first though as it will turn to balsa wood.
- elan_fan
Last two times I did a head gasket change and decarbonised the pistons, I used a method I learnt with old motorbikes. First, work some clean grease (castrol LM) into the gap between the pistons and the bores; Rag strips in the bolt holes and water ways and thoroughly clean the block face. Then use a selection of suitable tools (various favourites - steel rule for the flat bits and an old screwdriver for the valve cutouts) to carefully remove the carbon. My steel rule is old and has lost the sharp edge, so is slightly blunt and pushes the carbon off rather than digs it off. This will be heresy to some but what the hell.... Be very careful not to scratch the piston itself. The main thing is to get the chunky bits off rather than have a high polish! When the pistons are reasonably clean, and all carbon dust and chunks have been cleaned away from the working area, carefully dig out the grease, along with any carbon bits embedded in it. I find a cocktail stick perfect for this. It helps to gently move the crank to move the pistons up & down to clear up the odds and ends of grease (don't lose the cam chain!). When all is clean, and no more bits can be seen (or felt), work a little fresh engine oil between piston and bore, and swill around with a fresh cocktail stick. Clean out the oil with the edge of a clean rag.
Prepare the block face for the gasket and complete the job!
Easy
Jeremy
Easy
Jeremy
JJDraper - Coveted Fifth Gear
