Lotus Elan
Oil Pump
PostPost by: Gizze » Mon May 16, 2005 5:28 pm
Having just purchased my +2 a couple of weeks ago, I thought I'd tackle the engine jobs first, and in the process I'm trying to remove the oil pump - the engine's still in the car, but I can't see a way of getting it off because of clearance against the chassis - surely there must be a clever trick which allows me to do this without removing the engine? If someone could tell me what it is I'd appreciate it!
Gizze
PostPost by: john-c-elan+2 » Mon May 16, 2005 9:52 pm
SUPPORT THE ENGINE WITH A JACK (BLOCK OF WOOD BETWEEN JACK & SUMP)
UNDO ENGINE MOUNTS EITHER SIDE, JACK UP ENGINE ENUFF FOR OIL PUMP
TO CLEAR O/S CHASSIS. UNDO PUMP & REMOVE. I DID MINE THIS WAY ?
RGDS jKC
john-c-elan+2
PostPost by: Gizze » Mon May 30, 2005 8:17 am
Worked a treat - many thanks
Gizze
