Suggestions on lifting a stubborn valve cover?
PostPost by: Chrisrich » Tue Aug 28, 2007 4:26 am
The previous owner had used so much sealant around this valve cover that I can't get to to budge. Is there any special (non-distructive) technique I should know about? I could put an engine hoist above it or course, but where and how to grab it?
Thanks!
chris
Chrisrich
PostPost by: cliveyboy » Tue Aug 28, 2007 7:07 am
My suggestion would be to get a bit of piano wire and wrap it around two bits of wood and try and use it a bit like a cheese cutter. You are less likely to damage the sealing face than using the screwdriver method
Clive.
1972 Elan Sprint FHC
cliveyboy
PostPost by: oldokie » Tue Aug 28, 2007 7:43 am
Clive has the right idea but I use a guitar string, .010 high E. Any good music store will sell you one at a time because serious pickers like to mix gauges.
Gene
oldokie
PostPost by: Chrisrich » Tue Aug 28, 2007 1:15 pm
VERY interesting. I happen to have a .010 guage string 5 feet away. How convenient. What do you think: just wrap it around two dowels, place it in the joint and pull?
Chrisrich
PostPost by: 1964 S1 » Tue Aug 28, 2007 2:24 pm
Yes, I think you've got the right idea. Also, when you come to areas where the wire hangs up or can't cut through, try a single edged razor blade or matt knife, eventually the cover will be loose enough to pry off. but avoid using a screwdriver until you're sure it won't damage either surface.
1964 S1
PostPost by: lotusanglia1965 » Tue Aug 28, 2007 8:44 pm
Miles Wilkins recommends "shoving" a big screwdriver through the cork gasket at the rear on the bridge part of the cover,where no oil leaks can occur. seems logical to me,less hassle too! :wink:
"He's not the messiah, he's a very naughty boy"
Monty Python's The Life Of Brian,best film ever.
lotusanglia1965
PostPost by: Chrisrich » Wed Aug 29, 2007 1:18 pm
Eureka.
A combination of the former and the later did the trick.
The drama continues.
Thanks, fellows.
Chrisrich
cron
