Valve guides
PostPost by: saildrive2001 » Fri Aug 24, 2007 12:11 am
I am ready to replace my valve guides & wondered if it is necessary to put a backing support in the valve spring seat area when driving out the old guides. Any advice would be appreciated.
Keith Marshall
saildrive2001
PostPost by: carrierdave » Fri Aug 24, 2007 9:48 am
Hi there,
Ultimately it is dependant upon how you remove them. What I did was to drill out almost all of the middle of the guide before attempting to remove it. I then used a drift to drive it out. Because most of the material/strength has been removed the guide tends to either collapse inwards or fracture as it is removed.
Dave
IMG_0341.JPG and
carrierdave
PostPost by: john.p.clegg » Fri Aug 24, 2007 3:10 pm
If you heat it to the required temperature (not sure off the top of my head) and work quickly,they will come out whole.Just have everything in place to hand and try to keep the head covered (to keep the heat in)
John :wink:
PostPost by: saildrive2001 » Fri Aug 24, 2007 3:36 pm
So you didn't have anything to support the area around the valve guides when you drifted them out? I was worried about having problems with distorting or worst cracking the head when I hammered them out.
Keith Marshall
saildrive2001
PostPost by: john.p.clegg » Fri Aug 24, 2007 7:33 pm
Keith
Yes,no problems..
John :wink:
PostPost by: reb53 » Sat Aug 25, 2007 6:54 am
Keith,
Yep, no problems for me but it was heated up to the recommended temp.
Can't remember what that is but it's in the book somewhere.
Actually fitted in the oven, (wife wasn't home....).
Ralph.
reb53
PostPost by: handi_andi » Sat Aug 25, 2007 9:06 am
On that subject, have always been tempted to use the dishwasher as a degreasser, has anyone tried this? Given I am now divorced, and in fact ex gets remarried today and its raining, I don't have to worry about getting in trouble!
Andy
handi_andi
PostPost by: bill308 » Sat Aug 25, 2007 1:14 pm
Just a note of caution, hot water and strong detergents can etch and pit aluminum. So be careful.
Bill
bill308
PostPost by: handi_andi » Sat Aug 25, 2007 1:16 pm
Good point, have seen that on aluminum utensils, better limit it to steel parts only then. Always thought it would be good for cleaning up the socket set though
Andy
handi_andi
PostPost by: tdafforn » Tue Aug 28, 2007 10:45 am
Have tried using the dishwasher (on my sockets and spanners) and it was a disapointment..
I guess the detergent isn't up to engine grime!
tdafforn
PostPost by: cabc26b » Thu Aug 30, 2007 12:50 am
You mean your wife/girlfriend won't scrube them down with solvent for you ?
PostPost by: bill308 » Fri Aug 31, 2007 1:43 am
Andy,
You probably need to use hotter water and more detergent to get the cleaning power. Use the pots-n-pans cycle.
Bill
bill308
