Engine mounts again
After all the discussion on the quality of rubber parts at the moment, I'm wondering what to do about my need to replace the engine mounts.
First off, I have a Plus 2 Spyder spaceframe chassis - do I need to use Spyder engine mounts or are they the same as to Lotus ones?
2. Are the Spyder mounts subject to the same questonable rubber quality as the Lotus ones?
3. Can I use TTR uprated mounts in a Spyder chassis?
I've been browsing the archives but I'm just getting confused
Thanks in advance for advice and opinions!
Robbie,
you can use TTR engine mounts with your Spyder chassis, they also do an uprated g/box mount which may be of interest.
I have these parts fitted to my Zetec engined Spyder chassis Elan.
Beware of the Illuminati
Errrm, I don't know
Robbie,
Yes, +2s use two of the standard Ford engine mounts. The only car that used the 'tall' Lotus special mounting was the Stromberg 2-seater Elan.
****NO IT WASN'T - IT WAS THE WEBER/DELLORTO 2-SEATER ELAN - THANKS BILL - SEE BELOW...****
Matthew
Matthew
- ppnelan
Bill,
The old engine mounts removed from my weber Sprint are both the same size.
Stuart.
Stuart.
- stuartgb100
Bill is correct, on the small Elan (with the weber/delloto engine) the r/h engine mount is a Lotus only item while the l/h is a standard Ford mounting, the stromburg engine use's both standard Ford mountings (also used on the Europa)
Not sure about the +2 but think it uses both standard mounts and I also believe the Spyder chassis uses standard mounts but turned upside down?
There still does not seem to be a definitive answer to the original +2 question apart from Mathew's comments.
Having bought "the whole shooting match" from Spyder I can state catagorically that for my Stromberg engined Elan they supplied one standard & one tall mount for use with their space frame & their engine brackets.
From the S1, S2, and coupe parts book that is on line (you can download it here - http://dialspace.dial.pipex.com/mce/Elan/Documents/ ) on
page 40 PB57 states
RH is 26 E 374 Lotus part
LH (F) 109 E6068 Ford Part
this is with the stock Lotus Chassis
The 3 Spyder chassis I've bought use the Ford Part on Both sides, at least on Elan,
The Plus 2 may be different but I have heard from other people that have them that they are the same part on both sides for the stock chassis,
I can't see why Spyder would go with different mounts on the Plus 2.
I am no expert on Plus 2's, I sold my Plus 2
9 months ago to pay the New England heating bill and 6 months worth of taxes on my house. The only work that I did on it was to shim the cams and got it running after sitting for several years.
page 40 PB57 states
and to add a little more .........with standard Lotus chassis the Lotus +2 parts manual give both engine mounts as A26 E 6011
The small Elan parts manual :
026 E 0374 R/H
054 E 6000 L/H
and then 026 E 6011 from eng # ....... (not specified)
and from the D.Bean manual :
026 E 0374 R/H for Weber carbed Elan
026 E 6011 for L/H Weber Elan also L/H & R/H for Stromberg Elan & Europa.
The Bean manual does not show a difference between Elan and +2
As for Spyder chassis's I think only Spyder can answer that or a call to TT to see what is compatible
026 E 0374 R/H
054 E 6000 L/H
[quote="types26/36/74"]
026 E 0374 R/H
054 E 6000 L/H
If this is correct (if any Lotus CAN be correct) then Stuart could be right ....may be the later chassis's did take both the same mounting? although I have fitted the high mounting to the right side on my Sprint and that is a Oct 72 build.
026 E 0374 R/H
054 E 6000 L/H
Brian,
I think you've got it.
A phone call to Spyder would get the original question answered
I don't recommend phoning TTR with questions about Spyder chassis
My Sprint has an early Spyder chassis. The engine mounts removed are basically the same size, but the mounting holes are different for each side.
I replaced them with TTR's uprated mounts. I don't recall having to tell them it was a different (ie Spyder chassis).
If it's of use, I'll post some pictures when I get home this evening.
Stuart.
Stuart.
- stuartgb100
