water pump
• Page 3 of 3 • 1, 2, 3
It?s a bit tight, but there is some give when it?s on. It "rolled" on easily on the second try.
Elfin Monocoque (Twin Cam)
[email protected]
[email protected]
SJ Lambert - Fourth Gear
The S1 Esprit belt arrangement is identical except you have to lie on the engine and fit it deep down a 50 mm gap between the front of the engine and the firewall. Done it twice in 40 years and the time is coming to do it again
I find it easiest to fit one of the pulley bolts with the belt in place and then turn the engine until another pump pulley bolt lines up.
ON a twink the smaller race crank engine pulley improves the clearance on the tacho drive as well as slowing the water pump down to design speed in a 9000rpm engine. I have a front cover that has a tacho drive that is blanked off as i dont use it but a flat is needed on the blanking plate on the belt side if used with a standard crank pulley.
billwill wrote:Wot no dynamo or alternator?
Have Ctek charger and Varley Red Top will travel!!
[email protected]
[email protected]
Users browsing this forum: pdenton26 and 28 guests
