Spark plug question
PostPost by: peterako » Tue Jun 05, 2007 8:36 am
Hi again!
Any opinions on spark plugs?
I usually use the standard NGK BP6ES plugs and have no complaints.
Recently I bought what I thought was a large box of:
BP6ES plugs
from my local motor factor only to discover that they were:
BP7ES plugs.
Now, my understanding is that the BP7ES is a 'hotter' plug.
Any opinions on whether they'll perform as well as the standard 'colder'
plug?
As always, thanks in advance,
Peter 1973 +2S 130/5
peterako
PostPost by: richardcox_lotus » Tue Jun 05, 2007 8:53 am
Hi Peter !
7's work OK unless you are always stuck in traffic, as they do foul & take an age to clean up. For that reason I changed FROM 7's TO 6's last year & my general running is much improved.
I would keep them as an emergency spare.
PostPost by: gjz30075 » Tue Jun 05, 2007 2:00 pm
peterako wrote:Now, my understanding is that the BP7ES is a 'hotter' plug.
I'm pretty sure with NGK plugs, the higher the number the cooler the plug.
Can anyone confirm?
I changed from 6's to 5's for improved running.
Greg Z
'72 Sprint
PostPost by: andyhodg » Tue Jun 05, 2007 8:53 pm
My understanding is that the lower the number the hotter the plug. I run BP7ES's They do tend to foul on occasions but I feel that the engine is happier on 7's rather than 6's.
Nothing concrete just a feel.
andyhodg
PostPost by: types26/36 » Tue Jun 05, 2007 9:01 pm
andyhodg wrote:My understanding is that the lower the number the hotter the plug. .
Yes that is correct see this link:
http://www.kaila.net/tl125/tl125ngkcode.html
types26/36
PostPost by: steveww » Wed Jun 06, 2007 7:38 am
NGK numbers work the other way round to Champion see
http://www.spark-plugs.co.uk/pages/tech ... l_code.htm
steveww
PostPost by: twincamman » Fri Jun 08, 2007 6:04 pm
after many years of using champion plugs I have switched to nkg because one of the little screw tops fell off the plug and went to live in the number 2 plug hole ----had I not heard the click and started the car with the new plugs in place and the offending bit in the piston hole it would have been very expensive ---ed
FDFB8087.JPG and
twincamman
PostPost by: oldokie » Fri Jun 08, 2007 9:19 pm
Got that right, my #4 inhaled a nut that was supposed be holding the stack on the back Weber. Sounded like a goober thrasher workin' rock! Got all the carbon off the piston, though.
Gene
oldokie
Users browsing this forum: CG901 and 59 guests
