another thread question!!
PostPost by: tower of strength » Fri Jun 01, 2007 8:35 pm
Any idea what the thread on the throttle cable adjuster, where it screws into the pedal box on a plus 2? mines sheared off flush and needs drilling/tapping
tower of strength
PostPost by: mikealdren » Mon Jun 04, 2007 2:00 pm
Mark,
I've just had a look and I'm pretty sure it's 1/4" 26tpi BSF. At least the tap ran cleanly down my pedal box and the plastic adjuster sleeve now fits very smoothly.
The threaded sleeve on my cable is plastic, I hadn't noticed before, guess I'd assumed it was probably brass like the lock nut. You may be able to melt/burn the old one out with a bit of heat to save having to drill it?
mikealdren
PostPost by: CBUEB1771 » Mon Jun 04, 2007 5:17 pm
The throttle cable adjuster at the pedal box for the +2 is definitely 1/4 BSF (26 tpi).
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: tower of strength » Mon Jun 04, 2007 8:47 pm
thanks guys
tower of strength
Users browsing this forum: No registered users and 68 guests
