Sump Seals
PostPost by: tdafforn » Fri May 25, 2007 10:47 am
I am about to put the sump pan back on the rebuild.
I have a question about the seals at either end of the sump.
I have two types, cork or rubber (then engine had rubber when I took it apart.)
The rubber ones do not fit very well (the bit which locates in the grove in the front cover is too big)
Are the cork items up to sealing, or should I hunt down some rubber ones that fit?
tim
tdafforn
PostPost by: david.g.chapman » Fri May 25, 2007 11:12 am
I have used the cork seals in the past with no problems. They have been supplied to me slightly too long, and I have cut them down to suit. I smear some RTV on the mating surfaces to make sure.
Dave Chapman.
david.g.chapman
PostPost by: types26/36 » Fri May 25, 2007 12:16 pm
Depends on which rear crank oil seal carrier you are using, the 711 has wider groves to take the rubber sump seals but the 711 front rubber sump seal is to wide for the T.C. front timing cover grove.
1. You could use the T.C. rear crank carrier and the cork seals from the T.C. set or
2. you could use the 711 rear crank carrier with the 711 rear rubber sump seal and the cork from the T.C. set at the front.
Third option is to get some round section rubber (of the correct size) and make your own........hope you understood that
types26/36
PostPost by: kenny » Fri May 25, 2007 12:33 pm
Snap, just come in from garage for a butty...........Just fitted front timing case, rear cover and sump.
I used the cork gaskets with"threebond 1215" smeared on both sides of all surfaces........that stuff matches my grey engine too :wink: .
Kenny
kenny
PostPost by: steveww » Fri May 25, 2007 12:39 pm
I have always used the cork items with no problems. They are usually too long and need a little trim. RTV on both sides and no leaks :)
steveww
PostPost by: tdafforn » Fri May 25, 2007 1:57 pm
think I'll go with the cork front and rubber rear with 711m housing.
I wonder where the previous owner got the rubber ones for both front and back on a standard twink block?
tdafforn
PostPost by: types26/36 » Fri May 25, 2007 2:12 pm
kenny wrote:Snap, just come in from garage for a butty...........Just fitted front timing case, rear cover and sump.
Kenny, just a tip (although you might know) when fitting the front t/case, fit and loosly tighten the crank pully BEFORE tightening the t/case bolts, its to centrize the oil seal in relation to the crank.
ps O.T. ........what butty did you have :lol:
types26/36
PostPost by: kenny » Fri May 25, 2007 3:41 pm
Brian, A pre packed chicken and bacon :wink:
And no I didn't think about centralising the cover with the pulley :cry:
Miles never said :shock:
Should be ok shouldn't it :?:
Kenny
kenny
PostPost by: types26/36 » Fri May 25, 2007 4:02 pm
kenny wrote:Should be ok shouldn't it :?:
Yer, oil drips are considered normal!......(well by some) :lol:
......could be O.K......just the luck of the draw......
types26/36
