Cam Cover Red Paint
• Page 1 of 4 • 1, 2, 3, 4
Greetings everyone,
I've done a forum search and can't seem to find a definitive wrinkle red paint part number or something that I could get to redo my cam cover. Although I did find many debates on the red/blue/black color that it *should* be! I know that mine needs to be red, but I'm having a hard time finding the right paint.
Anyone have any leads on where to get it? Manufacturer / color / part number / application guide?
1970 Lotus Elan +2, 1991 Lotus Elan, 2006 Lotus Elise, all for sale.
Hegg - Second Gear
The red is know as Poppy red supplied by Trimite Ltd and is a stove enamel finish. QED can supply the engine paint.
Karl
1970 S4 FHC SE
1970 S4 FHC SE
fasterbyelan - Third Gear
I saved the link for reference from a previous post:
http://www.frost.co.uk/item_Detail.asp? ... h%20(310ml)
It may help.
Brian Clarke
(1972 Sprint)
It may help.
Brian Clarke
(1972 Sprint)
bcmc33 - Coveted Fifth Gear
Correct me if I'm wrong but I don't think that the red cam covers were wrinkle finish. I found that red Sperex VHT was a perfect match for mine.
I painted the block in a grey tractor enamel because it looked right and was subsequently told that it was the correct colour though I can't remember which tractor was grey. Fordson, Massey Ferguson?
- timliggins
ppnelan wrote:Massey Ferguson, I believe.
Matthew
According to the Twin-cam guru, Miles Wilkins, the nearest paint to Lotus Grey is Massey Ferguson Stoneleigh Grey with a touch of blue added. Can't tell you what blue though
Karl
1970 S4 FHC SE
1970 S4 FHC SE
I found a local supplier at:
http://store.summitracing.com/egnsearch ... 4294863504
(in case someone in the US finds this thread in the future)
Thanks for the help! Now to find the grey....
Hegg - Second Gear
I bought the red wrinkle from Frosts for the cover. Haven't used it yet but have seen a cover done in it and it liiks great.
As for the grey there seems to be no definitive answer to this one The concencus always seems to be MF grey with a hint of blue/black.
My Local Lotus man has said forget that and to buy oil based "Shark Grey" from local paint shop.
Would like thoughts on this one as I need to paint the block shortly for rebuild.
Kenny
Kenny
- kenny
- Graham Arnold once said ; - " we used to send the youngest guy out with a 10'er to buy a can of Battleship Grey for the blocks......"
Not very precise I guess......
DH
DH
Dag-Henning - Third Gear
Whatever colour you paint the block it'll eventually end up multgrade black (or am I just being cynical!)
Actually I painted my block last night with QED grey block paint, looks great..
Question now is what to do with the other 400mls left over, anyone want some?
tdafforn - Coveted Fifth Gear
kenny wrote: As well as the block do you paint the head and timing cover and sump in the grey?
Lotus painted the head,block,timing cover & sump in grey but I only paint the block and sump.
It would seem the oil filter canister (if you have the old cartridge type) is also painted the same grey.
At least on mine...
I always kind of assumed that the block was in Ford Gray since it was a Ford block. Perhaps all the grays are similar enough that nobody could tell the difference anyway....
At least on mine...
Hegg - Second Gear
Users browsing this forum: elanner, Mallydeganwy and 19 guests
