The oil pressure is back!
PostPost by: Emma-Knight » Mon Apr 23, 2007 11:44 am
...well - it wasn't really gone :roll: the rebuilt dual gauge indicator was loose! Refitted the old Motometer single oil pressure gauge and: 45 calibrated psi on idle after starting.
The oil pump needed fired engine speed to bleed air out - took about 20 sec. from start.
My engine pre-oil system via air pressurized eezibleed / oil filter central mounting thread (3/4 UNF hydraulic fitting) worked great! The engine was full of fresh Duckhams while the starter cranked.
Happy Anna :wink:
1965 S2
Emma-Knight
PostPost by: Evan Carpenter-Crawford » Wed Apr 25, 2007 11:36 am
"My engine pre-oil system via air pressurized eezibleed / oil filter central mounting thread (3/4 UNF hydraulic fitting) worked great! "
OK...howzatgoagain?
sounds interesting, please elaborate.
thanks,
-E
Evan Carpenter Crawford
1969 FHC 8624
First Gear
First Gear
PostPost by: Emma-Knight » Wed Apr 25, 2007 12:23 pm
I'll post a photo on friday - that will explain. (eezibleed is the name for the Gunson brake bleeding air pressurised sytem)
Anna
1965 S2
Emma-Knight
Users browsing this forum: No registered users and 66 guests
