Re Fitting Engine
Gents,
Will the twincam engine go back in with the tubular exhaust manifold pre-fitted?
Took it off to get it out but not sure about when putting it back.
thanks
thanks
In the past i've found it a struggle to fit the manifold after fitting the engine.
This year i left the two manifold sections on (minus the y piece) and found it a lot easier
Never tried to refit an engine with the manifold (header ?) attached, I find the best way is to lay the manifold in place, fit the engine then fit the manifold to the head, I have on occasion removed the exhaust studs then refitted them once the engine is in.
This was because it was not a qenuine Lotus manifold but an after market unit which was a one piece and not the two piece as per Lotus.
Brian.
Brian.
I find that I have to fit the engine in with the LH engine mount off, fit the manifold and then fit the LH mount otherwise it's too much of a squeeze to get the manifold onto the head without taking out some of the manifold bolts.
pereirac - Coveted Fifth Gear
The header on my S2 Elan needs to be removed on the way out of the car, and dropped into place shortly before the engine is fully aligned with the transmission on the way back into the car, otherwise I have to pull it partway back out to install the header - won't fit in any other way! Though I suppose some headers might be different.....
Dave
lotus026
Dave
lotus026
- lotus026
