twincam cam cap numbering???
just took off my cams for valve adjustment. Noted the location of the cam caps meticulously. For inlet cam number 1 to 5 from back to front (of car) and for exhaust cam number 6 to 10 from front to rear (of car).
In Miles Wilkins Twin Cam Engine book is a picture (page 88 top), where one can see the sequence of the exhaust cam caps. It?s the same as on my engine.
In my Original Lotus Workshop manual (section E pg 14 top ) the numbering sequence for the exhaust cam caps ist the other way, i.e. number 6 starts at the back an number 10 ends at the front near to the timing housing.
As I know it?s very important to assemble it the same way it has been line bored once I?m a bit confused. Which is correct? Or did the numbering sequence change at some point?
Any ideas or experience with this topic?
Juergen
Juergen
J. Grams, Germany
?70 Elan S4/SE
?70 Elan S4/SE
- elanbaby
Juergen,
My cam bearing caps are also different fron the diagram in the shop manual. But I match the number stamped on the bearing cap with the number stamped on the head, and I disregard the manual in this case. It seems that even the factory had a tendency to ignore the manual when it was expedient.
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther - Third Gear
Today I scraped off the remains of the cam cover gasket and discovered the corresponding cam cap numbers stamped into the head.
Exhaust cam numbering just as the numbers on the caps I removed. And the other way round than in workshop manual.
OK, I?ll stick to the number sequence on my head of course.
Thanks a lot for your quick answers and help!
Juergen
Juergen
J. Grams, Germany
?70 Elan S4/SE
?70 Elan S4/SE
- elanbaby
Users browsing this forum: CG901 and 22 guests
