cleaning cylinder head
PostPost by: tdafforn » Sun Nov 19, 2006 8:37 pm
Have just removed the head from my twink.
(I am aiming to recondition a 711m bottom end to refit before spring)
Anyhow, now I have the head it could do with a bit of a decoke.
there is plenty of evidence of oil burning which has left a load of carbon on the head (which has been rebuilt in the past 5K miles)
So what do you guys suggest to clean off the carbon without damaging the head?
tdafforn
PostPost by: tower of strength » Mon Nov 20, 2006 12:08 am
I use 3Ms "ROLOC" bristle brushes in an air powered die grinder, I guess you could use them in drill with an arbour and backing plate. I use the green cup type brush to remove gaskets and carbon from alloy and steel,
I tried 3Ms web site for a link, but its not very helpful, I'll have a hunt and see if i can find a link for you
tower of strength
PostPost by: rgh0 » Mon Nov 20, 2006 10:38 am
My local engine specialist machine shop uses soda blasting for cleaning alloy heads, I have done it with a couple of twink heads and it does a nice job of cleaning them up with zero damage to the alloy. Once you have finshed blasting you rinse the head and any remaining soda dissolves away.
regards
Users browsing this forum: No registered users and 45 guests
