Redline+new Rubber Cresent Inserts=trouble
Heads up the new rubber inserts to seal the cam cutouts in the head are junk. They swell up within a matter of days and push their way inside the engine. This is because the side in contact with the Redline oil is swelling to about twice the volume. More counterfeit crap! I'm forced to make my own out of aluminum today. Bugger! I'm going to be working into the evening hours tonight to gat my car back on the road I can tell.
- type26owner
do you meen the halfmoon cut outs ?if you do use the original ones .they are cheep too.put a little rtvon the head to sit them on and some rtv on the top of them.slap on a new cork gasket originall again should do the trick
- mikefromengland
Keith, I've used the ones VW used for the early Golfs. They're black in color and work fine. Try to find a import place that'll sell just the pieces you need, otherwise you'll have to buy the whole top end gasket set.
Greg
Greg
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Mike,
Those new rubber halfmoons were installed just a couple of weeks ago. The only reason they did not pop all the way into the engine is they hit up against the heads of the bolts holding on the camshaft gears and the pipe plugs in the farend of the cams.
Greg,
Couldn't fool around since it's a Sunday and it's need for the commute tomorrow. Made ones out of 6061 Aluminum today and glued them in with RTV Silicone.
I've never had the older halfmoons do this crap. I'm getting less tolerant of getting screwed when I spend my hard earned money. I'll take a picture of these things and link to the post tomorrow.
Greg,
- type26owner
These took only a matter of severals weeks to get this condition. :angry:
- type26owner
