Vacuum Headlight Thingys
Whilst taking the vacuum pod thingys off, to sort the rust before it went through, I snapped the bottom stud. Can I replace it or do I have to buy a new unit? Please bear in mind that I have run out off money on the rebuild (well alright the wife saw my credit card bill) and just want to get my plus 2 back on the road.
Jack
Jack
- Jack
They were originally brazed on, at least mine were. I would expect that if you could get someone to mig weld a new bolt/stud on quickly enough to not melt the diaphragm you should be good to go. I would make sure that you did have the diaphragm up as far from the heat as possible. 2 or 3 quick spots should hold it on.
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
I mig welded a replacment 1/4 unf bolt on no prob once the brazed lug was removed and all trace of braze removed . Like previous post put diaphram in up position to be on safe side .
Rick
Rick
1968 Elan +2 . Now going back together after 18 years , you just can not rush these things .<br>Rick
flyinggellyfish - Second Gear
Should be no problem with a MIG welder (providing the person knows how to use it)
If you want belt and braces clamp some vice grips on the bracket above where you are welding to sink the heat away.
It really shouldn't be a problem.
