Early +2 H/lamp Vac Pipes
Can any one confirm the route the headlamp vac pipes take from the switch on dash through the bulkhead . The parts book shows it passing through on the n/s bulkhead with a grommet , but when I stripped the motor the pipes ran through the same hole as heater pipes on the os. This would make sense as vac switch is in line with this hole .
I just want to confirm this before I refit heater , wirring loom , basically the whole interior .
Ta
Rick
Ta
Rick
1968 Elan +2 . Now going back together after 18 years , you just can not rush these things .<br>Rick
flyinggellyfish - Second Gear
Thanks for your reply
Rick
Rick
