Head removal & replacement for dummies. What to avoid.
PostPost by: rgh0 » Mon Mar 03, 2014 9:00 am
pierrea76 wrote:Hello, removal of head is not at all staightforward.In fact, the only right way is to remove engine; Why? Just because it is impossible to avoid oil leakage if you try to re install the front cover in situ. cylinder head, for this reason is the worst job on a baby Elan! You can read the "yellow bible" to confirm! Please, excuse my bad english, i am french!
Hi Pierre
I agree if you are removing the front cover as well as the head, that its best to pull the engine for ease of access so that assembly can be done well. However if you are just removing the head itself then it can be done in the car quite easily.
PostPost by: pierrea76 » Mon Mar 03, 2014 2:58 pm
Hello Rohan, John said there is oil leakage on the front cover gasket, making obvious to remove the cover...and it is a very boring job, because it is necessary to remove also the sump for a correct reassembly.If you make this job, it would be a pity not to "look after" the water pump, another precise and boring job...However, you are right, if you want just remove the head.The first time i made this job, it was in 1973 on the Elan of a friend(i was student to become a lawyer) and today, more than forty years later, i still don't know how i made, but all was OK!The "yellow bible" is Brian Buckland's book.Pierre
pierrea76
New-tral
PostPost by: billwill » Mon Mar 03, 2014 6:08 pm
There are many ways to do these tasks and each of us work out our own preferred method. This topic from the beginning is a good guide to removal of the cylinder head with the engine in the car. A task I have now done many times.
And I have even found on at least 2 possibly 3 occasions that I can replace the front timing case with the head in situ, but you need to lower the sump a little and you need to cut new cork gaskets (for top and bottom) accurately to fit the exposed parts of the front case an in addition to the normal gasket sealant you need an extra blob or two in the corners where you now have a cut in the cork gaskets.
As to being easier to take the head off after taking the engine out, I find it better the other way. If you take the head off in the car then it is then much easer to get the rest of the engine engine out without it.
PostPost by: rgh0 » Mon Mar 03, 2014 10:23 pm
pierrea76 wrote:Hello Rohan, John said there is oil leakage on the front cover gasket, making obvious to remove the cover...and it is a very boring job, because it is necessary to remove also the sump for a correct reassembly.If you make this job, it would be a pity not to "look after" the water pump, another precise and boring job...However, you are right, if you want just remove the head.The first time i made this job, it was in 1973 on the Elan of a friend(i was student to become a lawyer) and today, more than forty years later, i still don't know how i made, but all was OK!The "yellow bible" is Brian Buckland's book.Pierre
Hi Pierre
I think the leak was from the top cork gasket on the front cover not the side joins to the back plate so he does not need to remove the front cover. While its possible to do virtually anything with the engine in the car my back prefers to work on engines on a stand at a comfotable height so I typically take the engine out if i have to do anything at all major these days !! You have been working on Elan engines even longer than me as I did my first rebuild in 1975 not quite 40 years ago yet :D
PostPost by: Johnfm » Mon Mar 03, 2014 11:25 pm
Pierre
Your English is better than my French...
Water pump seems fine - no leakage and no play. My mechanic is happy to leave it as is.
Will definitely check whether the threaded hole in the head needs helicoiling - the head is at the machinists tomorrow - so will have him check it for me.
1967 Plus 2 #0168
Johnfm
PostPost by: alan » Tue Mar 04, 2014 7:55 am
hi Johnfm,
i suggest you clean up the exhaust manifold stud holes and put copperslip on threads.
By the way what electronic ignition have you fitted, a hall effect :?:
Alan.B
alan
PostPost by: Johnfm » Tue Mar 04, 2014 8:34 pm
I fitted accuspark and the black box.
I have a 23D distributor and their magnetic excited ring needs adjusting to fit - which is a bit o a pain.
1967 Plus 2 #0168
Johnfm
PostPost by: Johnfm » Tue Mar 04, 2014 8:35 pm
Head was pretty square. Machine shop took 6 thou' off it I think. Head thickness now 117mm (4.6" in old money )
1967 Plus 2 #0168
Johnfm
PostPost by: Johnfm » Sat Mar 08, 2014 8:33 pm
Sump removed today for re-sealing.
That top bolt on the starter motor is a bit of a bugger!!
Will all be back together next week - can't wait to fire it up. Hopefully no leaks.
1967 Plus 2 #0168
Johnfm
PostPost by: JJDraper » Sat Mar 08, 2014 9:18 pm
Here's something to avoid..
http://www.ebay.co.uk/itm/STEEL-SEAL-HE ... 3cddbee4cd
Mind you, wish it worked on Twinks.
Jeremy
PostPost by: billwill » Sat Mar 08, 2014 10:22 pm
Johnfm wrote:Sump removed today for re-sealing.
Not if you use a socket spanner, a long extension bar, a universal joint, a short extension and finally the T-bar or ratchet handle.
PostPost by: john.p.clegg » Sun Mar 09, 2014 8:30 am
JJDraper wrote:Here's something to avoid..
Jeremy
Just for twincam heads...
http://www.ebay.co.uk/itm/ALUMINIUM-REP ... 258aa3f323
John :wink:
PostPost by: Johnfm » Sun Mar 09, 2014 12:41 pm
I went from underneath and just used a 4 " or do extender. I think when I replace I will remove the fuel pump and go from the top.
Glad I took it all apart - nice to know the bores are good, the valves are good etc.
1967 Plus 2 #0168
Johnfm
Previous
Users browsing this forum: clubsport and 25 guests
