camshaft broken
• Page 3 of 3 • 1, 2, 3
>The only issue is that the engine gives out a little puff of black smoke when you first rev the engine
That is probably normal behavior & is caused by small amounts of oil seeping down the valve guides
I checked cam timing again and found that the inlet cam was a tooth out on the drive sprocket, once changed the smoke was reduced and engine ran better.
- tim littlewood
