What's the best radiator solution
PostPost by: Carlos A » Thu May 28, 2009 2:33 am
And yet another pic.
Regarding the air filter I bought the black and yellow hose and the filter and made a bracket.
IMG_1588.jpg and
http://yourgarage.nbc.com/cars/Lotus1970?vehicleID=112804
BUY GAS WITHOUT ETHANOL: http://www.pure-gas.org/
Carlos A
PostPost by: GrUmPyBoDgEr » Thu May 28, 2009 12:28 pm
Hi Sean,
I'm very sorry.
I have re-read that which you wrote & have realised that I misread your first statement regarding flow rates.
At that time, I was like yourself, thinking we've gone full circle here & my missinterpretation of your posting lead to my reply; which now on reflection was totally unnecessary.
To put the records straight I have corrected my reply; not having found the delete button.
It was because I thought we were at loggerheads about coolant flow rates that I did the shouting & regardless of being right or wrong it was inconsiderate & very ungentelmanly of me.
For that I appologise not only to you but to all on the Forum.
Needless to say I'm sure that I'm not alone in saying that I'm pleased that you did decide to reply & as such drawing my attention to my error & bad behaviour.
My appologies to all :oops:
Beware of the Illuminati
GrUmPyBoDgEr
PostPost by: Carlos A » Thu May 28, 2009 1:31 pm
Blanking plates I made. No air around the radiator!
IMG_1647.jpg and
IMG_1649.jpg and
IMG_1643.jpg and
Carlos A
PostPost by: alaric » Thu May 28, 2009 2:03 pm
Crikey John, now I'm embarrased. I do get a lot out of this forum and really don't want to fall out with anyone, so it's a relief that we've all moved on.
All the best.
Sean.
alaric
PostPost by: GrUmPyBoDgEr » Thu May 28, 2009 3:28 pm
alaric wrote:Crikey John, now I'm embarrased. I do get a lot out of this forum and really don't want to fall out with anyone, so it's a relief that we've all moved on.
All the best.
Sean.
Friends then? :)
GrUmPyBoDgEr
PostPost by: hatman » Thu May 28, 2009 4:37 pm
Get a room you two.
hatman
PostPost by: alaric » Thu May 28, 2009 4:46 pm
Thanks for the pics Carlos. I'm going to have a go at trimming the rad this afternoon. I've attached a few piccies. I had it painted black by the supplier. They left off the filler neck and gave me a discount for the priviledge - they assemble them to order. The kenlowe fits to sturdy lugs on the body of the rad. I had a radiator fall apart once due to the weight and vibration of the fan; it was mounted through the cooling fins using nylon locking ties. I've run the new Kenlowe fan from a power supply, and it's very very smooth, so I'm sure this set up will be fine. I asked them to fit lugs for the other side too, but held off on the second fan until I'm sure I've room; my car seems to reject fitting of parts - it's too comfy in the garage!
Sean.
Looking into the inlet at the face of the temperature switch.
rad3.jpg and
The front with 9" Kenlowe.
rad2.jpg and
The back of the rad
alaric
PostPost by: alaric » Thu May 28, 2009 4:50 pm
John, of course. :) - that was never in question - just needed to clear the air.
All the best.
Sean.
alaric
PostPost by: GrUmPyBoDgEr » Thu May 28, 2009 6:00 pm
hatman wrote:Get a room you two.
Oh no, bet he's as ugly as sin. Besides, I've got age on my side, being only 63.
Why not join us & make it a crowd!
Sorry, wot I meant to say was "Bollocks" :lol: :lol: :lol:
GrUmPyBoDgEr
PostPost by: hatman » Thu May 28, 2009 6:21 pm
Can't argue with that. :mrgreen:
hatman
PostPost by: alaric » Thu May 28, 2009 10:31 pm
I have the body of an athlete, and am often mistaken for Patrick Swayze. These days I have my athletic body protected under a layer of fat and actually, now I come to think of it it's been a long long time since I was compared to the dirty dancing bloke. Oh no, I'm a middle aged fat bloke. Bother! :roll:
Sean.
alaric
PostPost by: elj221c » Thu May 28, 2009 10:38 pm
Oh, come ON guys!!
Anyway, back OT, what's wrong with the (S2) original Marston with a two bladed prop?
Worked OK for me commuting to the smoke in the hot summer of '76. :o
Roy
'65S2
(OK, I did replace the pump fan for am old MGB electric thingy later but only 'cos the two blade did nothing for pump bearings)
Roy
'65 S2
elj221c
PostPost by: alaric » Fri May 29, 2009 12:06 am
Wow. A fan on the water pump. That takes me back a few years.
The fan switch on my new rad is switch on at 95, off at 85. Is this about right?
Sean.
alaric
PostPost by: saildrive2001 » Sat May 30, 2009 12:07 am
A friend of mine here in Ontario used this product in his twin cam 7 & is also using it in his recently rebuilt Europa. The product is Evans NPG+. It is made by Evans cooling systems inc, Sharon, Ct. 06069 & is a synthetic product. Because the heat transfer is so good he runs the cooling system without a pressure cap, so no stress on the cooling system. It isn't cheap but surely is cheaper than new alloy rads. etc. but not as sexy.
When I finally finish the restoration on my S4 I am going to use this product since the Stromberg cars always run hotter.
Keith Marshall
saildrive2001
PostPost by: mikealdren » Mon Jun 01, 2009 4:01 pm
Roy,
Yes the fan helps reduce the bearing life even further and it also consumes a surprising amount of power and, most of the time, it's not required in normal driving except when stuck in traffic.
mikealdren
PreviousNext
