Alternative Vacuum Source?
PostPost by: shynsy » Mon Apr 29, 2024 11:38 am
I am not sure I am afraid.I suspect the ones that are out there are probably set up for modern negative earth configurations.
Current Cars: '72 Elan +2S130/5, '72 Triumph Stag 3.9L, '72 Spitifire Mk IV. Past Cars: '72 Triumph TR6 (supercharged), '70 MG Midget (K-Series + Type 9), '76 Triumph 2500TC, '72 Lotus Elan +2S130/4, '76 Triumph Spitfire 1500.
shynsy
PostPost by: Tmac897 » Mon Apr 29, 2024 1:12 pm
shynsy wrote:I am not sure I am afraid.I suspect the ones that are out there are probably set up for modern negative earth configurations.
Thanks for the quick reply.
Best
Tony
Tony
1967 Elan S3 SE
Northeast US
Tmac897
PostPost by: Phil.C60 » Wed May 01, 2024 7:57 am
Alternators with vacuum pumps usually require an oil supply and drain to make the pump work. Probably so much fabrication work to be rather impractical: you'd need a high pressure feed from the main oil gallery, and a return to the side of the block or to the sump above the normal oil level.
Phil.C60
Previous
