Cylinder liners
PostPost by: Craven » Tue Apr 12, 2022 2:47 pm
Liners are of superior quality material i.e. wearing properties for one and are considered a plus by many.
PostPost by: 2cams70 » Tue Apr 12, 2022 2:58 pm
Craven wrote:Liners are of superior quality material i.e. wearing properties for one and are considered a plus by many.
Ditto previous - you've missed the point of the argument!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: Craven » Tue Apr 12, 2022 3:08 pm
Thread titled Cylinder Liners
Just adding a comment, nothing to do with any argument.
PostPost by: alanr » Tue Apr 12, 2022 4:00 pm
I would argue..if you insist that you must argue, that having a linered engine back to standard size bore is a benefit and therefore adds value to a car.
Alan.
'71 +2 S130/ 5speed Type9.
PostPost by: 512BB » Wed Apr 13, 2022 6:53 am
'The lawyer in me says you can't make that assumption unless the fact that the block had been lined had been mentioned in the advertisement - which it wasn't of course'
No, but I think I can make that assumption as I provided an engine report which stated that the block had been linered and an invoice for the engine rebuild, which I know was in the file when the car was sold.
Certainly when ever I am comtemplating buying a vehicle for what I believe will fetch well over £50k, I read any and every document that pertains to that vehicle that I can get my hands on. If any prospective bidder on this car did not do that, then that was a matter for them.
Leslie
PostPost by: nmauduit » Wed Apr 13, 2022 9:57 am
alanr wrote:I would argue..if you insist that you must argue, that having a linered engine back to standard size bore is a benefit and therefore adds value to a car.
Alan.
I won't argue, yet I don't feel the same : depending on actual engine installation and liner specs, the linered engine may or may not be as strong as a non linered original, and may or may not have less rebore margin for overhaul down the road, so I would consider the pros and cons on a case by case basis, even if liner material would probably be of better quality than the cast block.
S4SE 36/8198
PostPost by: tonyabacus » Wed Apr 13, 2022 11:33 am
At what point does it become viable to recover items rather than scrap them, this is a dilemma that manufacturers are faced with at times. In the 1960-70's some manufacturers were using some tooling that was reaching the end of accurate manufacturing life. It is quite possible therefore that Ford were facing this issue with their engine blocks and hence the reason why the recovery scheme to put them back into service via their warranty and other schemes were in use. As Avro stated above, he has seen many blocks that fall into this category, we have to appreciate that the volumes of blocks needing this treatment is unknown. However with a company the size of Ford one would think the decision was taken after careful financial consideration.
In a similar context one has to remember we are talking mass production on a very large scale due to the variety of models fitted with this engine and its variants. I for one would not like to guess at the number of blocks produced with the Kent engine over something like a 15 year period let alone the number of potentially reclaimed blocks.
Are the blocks as good as a non lingered block, well as also previously stated many Ford blocks are linered in motorsport to comply with the relevant regulations and being used harder than most of our road engines. As long as the machining and matching of components are done correctly there should not be an issue. As to how much more or less a linered engine affects the value of a particular vehicle is something that the prospective purchaser has to evaluate against their own criteria.
Tony
tonyabacus
PostPost by: JohnMorin » Sat May 07, 2022 11:08 am
I didn't expect such much of a response. Thanks to all. One thing I would agree with is the greater wear resistance mentioned above. I measured my bores in several places before the rebuild with slip gauges and precision rollers and although there were visible signs of the pistons travelling up and down the bores the wear was barely measurable. This is after 40k+ miles.
1969 Elan S4 FHC, purchased in 1978, now with a big valve engine.
JohnMorin
Previous
Users browsing this forum: jmorley and 37 guests
