Radiator Cap Verification
• Page 2 of 3 • 1, 2, 3
Bonjour Phil,
you can throw the Cap from TTR in the trash bin
- alan.barker
MarkDa wrote:Yes - never mind 'not great' it looks to be non existent!
Does it even have a bleed valve?
If you mean the valve that allows coolant to flow back into the radiator? yes, it does, but it's not going to do anything if the top of the cap does not seal against the radiator neck at the top surface.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Hi Phil,
Quick google search brought up this from Car Builder Solutions in the UK.
https://www.ebay.com.au/str/CarBuilderS ... 0221134014
Two SS, 10lb, radiator caps, with seals, about a third of the way down the page. Both recovery type. One with depressurising valve.
Colin.
quote="pharriso"]Anyone got a Supplier / part number for a good Radiator cap with the correcty pressure & 2 Rubber Seals for the Recuperation system please? [/quote]
Colin.
'68 S4 DHC
- fatboyoz
How do you know it has 2 seals?
MarkDa wrote:Surely available in USA?
There are plenty of 10 psi radiator caps that will fit, the only way you know it will be suitable for the Elan with a Recuperation system is to specify a part number. I will see if there are any identifying marks on my old one that was "Made in Mexico" & works.
Phil Harrison
fatboyoz wrote:Hi Phil,
Colin.pharriso wrote:Anyone got a Supplier / part number for a good Radiator cap with the correcty pressure & 2 Rubber Seals for the Recuperation system please?
Thanks Colin, I think this one looks good - https://www.carbuilder.com/us/radiator-cap-rubber-upper-seal-10lb
Phil Harrison
Well regarding the correct Radiator Cap pressure this is slightly confusing...
My +2 Lotus Workshop Manual says the Cap pressure should be 7 lbs sq in.
My '71 +2 Lotus Parts Manual says that up to Chassis 0927 it should be a 10lbs sq in radiator cap and from Chassis 0927 it should be a 7lbs sq in cap.
Just checked my car and I see that currently fitted and seemingly working fine I have a 13lbs sq in Cap fitted!!
Alan.
Alan.
'71 +2 S130/ 5speed Type9.
- alanr
