Twincam engine weight please?
Okay... I might use the crane then. But i need to make the rope short otherwise I will lift it but I will be unable to push it inside the car....
Cooled down by CliveyBoy!
Pistacchio sprint 72 - Fourth Gear
Although I haven't moved an older twin cam (yet) by hand, I have moved the twin cam in my Exige S many times. I take a chain and bolt it to opposite sides of the block. Then I take a pipe or 2X4 and put it under the chain to lift. Only takes two guys and I have done it many times.
Trying to lift the engine with your hands only is difficult.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
I recently moved a tallblock engine minus the carbs in my Toyota avensis. I used a crane to get it in the tailgate and stood it on a piece of 7 ply. The only problem comes if you haven't made sure it cannot slide about. I thought mine was solid but it slid backwards on very gentle acceleration and took a chunk out of the trim
Mick.
Mick.
- Mick6186
Pistacchio sprint 72 wrote:Did you lift it by hand into the car or did you use a crane?
Both. Originally put it in the boot with a lift, but later realised that two strongish people can easily lift a dry engine.
On a related note though, encouraged by being able to lift and move a Twink, we tried doing the same with a Ford Essex, which nearly cost me an arm. Two of us managed to lift it, but there was no way we could manoeuvre it.
1967 Elan S3 S/E FHC
adigra - Third Gear
Pistacchio sprint 72 wrote:Okay... I might use the crane then. But i need to make the rope short otherwise I will lift it but I will be unable to push it inside the car....
Oh, this is a good point. It's actually easier if the rope is longer as one person can push the engine into the boot easier while the other lowers the lift. If you make the rope short, you'll have to be able to fit the crane under the tailgate. But, as I said above, two people should be able to lift a dry engine without too much issue (just lift with your legs!!! )
Adi
adigra - Third Gear
everything went fine despite under a heavy rain. The crane arm went into the rear of Ford C max
The day after I drove the engine to a motor specialist in italy.
Since then, I dropped it in italy.
Users browsing this forum: No registered users and 51 guests
