711M block
There is normally sufficient tolerance in the fixing points to do this.
Mine was shimmed up some.
P.O. Must have known about these issues, though!
It's easy to forget to do it as the build progresses, unless you understand the implications that can be caused later, by not doing it !
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
l10tus wrote:There is normally sufficient tolerance in the fixing points to do this.
I have been looking at doing this with my +2S, the proposition made more easy because I am putting in a new chassis. I do agree that not much adjustment is needed.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
I'll be using an alloy BDP block on my next engine build for my 1966 S2. I'm told this is as tall as a xflow so I'm worried about bonnet to cam cover clearance. It occurred to me that because the block is taller and it is a Weber head, that the thing to do for a little more clearance is to ditch the intake side motor mount that is made higher for the standard Weber head carb clearance and just go with the one used on the Stromberg engines. Does this make sense?
Bill
Bill
- bill308
Users browsing this forum: No registered users and 44 guests
