Kit form engine
rgh0 wrote:The cams are identical. The cam sprockets have a slightly different dowel hole location. If the holes are identical in location and the sprockets are not marked then you probably have 2 inlet sprockets as normally only the exhaust was marked with "Ex"
An Oxy torch on the block around the plug and then some freeze spay on the plug and it should come loose.
Hi Guys/ Rohan...
I had it right then. When I cleaned up the sprockets one was marked EXH ... As expected! The others are not marked and are the same. So jackshaft and inlet are interchangeable.
The owner has now been informed and he is taking the block to a local twinc engineering company AGRA Engineering of Dundee (google them). He is going to ask them to test the block thickness and will take it from there.. I have advised to have the block sleeved if not usable at 85mm...
The head looks fine and just need a slight skim now to clean up around the waterways...
keep you posted...
ab
ps... not seen the other set of cams yet!!
Alex Black.
Now Sprintless!!
Now Sprintless!!
billwill wrote:Well I have had a thorough search in my garage of all the places I would have been likely to store any cam followers but alas none found. So I only have this one here and I know not how I came by only one.
I had thought they would be with my oldest set of removed valves and I found those with some old steel valve guides but no other bits.
Hi Guys / Bill
Bill;
Sorry I missed your post here. Doh!! With the block thing ongoing right now followers are on the back burner, I have a set which are slightly concave and thinking of giving them a slight face off on the surface grinder,, Anybody got a feel for max removable? Couple of thou ok? I would think this would be fine,
Just need to get the surface finish!
Thanks all,, Wullie went a funny colour when I said I was not too keen to use the block untested, and we might need to sleeve it. He could see where I was coming from though.
He is trying to contact the PO to see if any light can be shone.
let you all know when I know.
Al' ....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Alex,
If, at any point, your friend starts to question if he spent his money unwisely, show him this:
http://www.ebay.co.uk/itm/Lotus-Elan-1967-S3-DHC-SE-Genuine-type-45/131250573097?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D23775%26meid%3D8943124220396225173%26pid%3D100011%26prg%3D10165%26rk%3D5%26rkt%3D10%26sd%3D171416889457
I have no idea if this sort of car ever sells at anywhere near the asking price... but I wish that I had rescued a few more ten years ago.
Pete.
http://www.petetaylor.org.uk
Pete.
[quote=
I have no idea if this sort of car ever sells at anywhere near the asking price... but I wish that I had rescued a few more ten years ago. [/quote]
Me too. But 50 = 50 hindsight is a wonderful thing.
Al' ....
Al' ....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Wow The registration on that car
http://www.ebay.co.uk/itm/Lotus-Elan-19 ... 1416889457
is OGU105E
and mine is OGU 108E
Gave me quite a jolt. I had to double check what my registration is.
is OGU105E
billwill wrote:Wow The registration on that car
is OGU105E
Easy bud!! It's to late to go throwing wobblers..
Al' .....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Tricky to do, but a way to ensure the surface of the cam follower is flat might be to mount a drill with grinding wheel on the cross-slide of your lathe and then spin the cam follower in the chuck while using the cross slide to move the grinding wheel over its surface.
hi Bill,
Many thanks again bud.
I could do the eight followers at once with the surface grinder + mag' chuck etc and good coolant,
Very accurate but need to see what the surface finish is like as I dont have many wheels right now..I suspect i will need grit 200+ to get the finish,
You have given me the bones of an idea though and using my lathe would work with the toolpost grinder set up..
The surfacer would be the best though... I might give the lathe a go for trial.. I have a couple of dud followers I might try to resurect.. See how it goes.
Al' ....
Al' ....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Hi Alex
If the followers are the chilled cast iron variety then a few thou off the face will be OK but you do need to achieve a high polish. If they are steel then they are nitrided and a few thou will go through the hard layer so you would need to nitride again.
def' cast Rohan.. I had a swipe at one edge with a sharp file / scraper. They should grind up ok.
but we are still on the lookout for a good s/h set. i will put a wanted out asap
Thanks buddy...
Al
Thanks buddy...
Al
Alex Black.
Now Sprintless!!
Now Sprintless!!
Hi Guys,
The surface grinding idea is a non starter so still looking for a decent set of secondhand ones,,
Must be in very good usable condition..
Anyone? PM me if you can help.
Alex B
Alex B
Alex Black.
Now Sprintless!!
Now Sprintless!!
