oil level dipstick
PostPost by: MickG » Thu Jan 09, 2014 4:30 pm
Just to confirm the above post and my previous posts I have now reinstalled the engine. I put in 4 litres of oil ( including filter) and giving my rather inaccurate way of measuring the oil level was just below the full mark. I gently tapped in the dip stick tube until the correct level was indicated. About an eighth of an inch. The height of the tube in my case (as previously posted) would have been closer to 4.5 inches and not 4.1.
I am now confident that I have the correct amount of oil where as before I estimate I would have been about a pint or so short. Not too much of a problem if you run at full all the time but more so if you let it drop to the fill mark.
Regards Mick G
MickG
PostPost by: Galwaylotus » Thu Jan 09, 2014 5:38 pm
AHM wrote:Mick G investigated this recently in this thread.
lotus-twincam-f39/dipstick-height-update-t29992.html
My post of the Elan wsm gives 4.1" and 4.5" for the Mk1 and Mk2 engines respectively.
I can confirm Mick's findings and have changed my dipstick tube to the correct height of 4.5" - 4.1" inches is way low, even at the full mark let alone the empty! and is probably the reason I (we) suffer from loss of oil pressure on right handers.
Next time you change your oil, fill it with 4 litres rather than upto the mark.
I concur and further suggest that the level on the dipstick is checked and noted when the 4 litres is in the sump. That way it's easy to monitor the true level between oil changes. :wink:
'67 S3 SE FHC
Galwaylotus
PostPost by: MickG » Thu Jan 09, 2014 5:41 pm
Good God at least someone agrees with me
Regards Mick G
MickG
PostPost by: AHM » Thu Jan 09, 2014 5:54 pm
And everyone thought you were 'barking' when you started your original post Mick!
AHM
PostPost by: MickG » Thu Jan 09, 2014 7:51 pm
Been said before and will no doubt be said in the future :D
Mick G
MickG
PostPost by: LCRJ » Sun Jan 12, 2014 2:48 pm
I thought 105E 6752 had a circular loop and that 105E 6752B had a rectangular loop. However, today, I found out the rectangular loop one that has 105E 6752 parts number.
Probably both loop available at that time?
Or Lotus Cortina has the circular loop one and Lotus Elan has the rectangular loop one?
It?s different length between 105E 6752 and 105E 6752B? and Lotus use 105E 6752B?
It is very complicated. Just let me know.
Hiro :D
LCRJ
PostPost by: Certified Lotus » Wed Oct 29, 2014 11:57 am
I am rebuilding an engine for my 64 Elan and the long block I bought did not come with an oil dipstick (this is a Cortina long block). So I took the one out of my current engine to look at it and then researched on this site to see what I could find. I have no idea if the dipstick that is currently in my car is original, but I need to acquire another one. Who sells these?
IMG_3249.jpg and
IMG_3248.jpg and
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: AlfaLofa » Wed Oct 29, 2014 12:05 pm
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa
PostPost by: Certified Lotus » Wed Oct 29, 2014 12:37 pm
Thanks Steve! I just bought it.
Glen
Certified Lotus
Previous
Users browsing this forum: 2cams70 and 35 guests
