Another question about Cams
PostPost by: rgh0 » Sat Nov 09, 2013 11:31 pm
collins_dan wrote:I just switched from l2 to qed 360. Both are about the same. Qed 360 has a bit more mid range torque. L2 are more high revving. The car has Sstrombergs and is very quick. Dan
Dan did you have L2 or CPL2 cams - The L2 cams were a longer duration approx 300 degrees and 0.35 cam lift which gave more top end but lacked mid-range torque compared to the QED 360 / Lotus D type Sprint / CPL2 cam which are all about 270 degrees and 0.36 cam lift ( 0.35 valve lift) and all should give essentially identical performance.
PostPost by: collins_dan » Mon Nov 11, 2013 1:48 am
Mine were L2. I don't have the specs handy (in Cayman Islands rights now), but QED's website is very good, or you can always call. They have very good service. Mine arrived in USA within a day or two of being ordered and postage was reasonable. All the bes, Dan
collins_dan
PostPost by: pauljones » Mon Nov 11, 2013 4:29 pm
When I initially looked into this it was the cost that put me off. But if I had the money I would get some QED 360 cams. I have had the pleasure of driving a plus 2 in a similar state of tune to mine but with these cams fitted. So much more torque and all through the revs too. Id like to drive a big block 420 spec as a comparison but at about ?1500 possibly more these days, and thats just for the top end, its a little steep for me. It really makes the zetec conversion look value for money.
I know it doesn't answer the current questions being asked with reference to cam specs. To get these I looked at web sites but strangely enough I didn't get QED specs.
All I can add to the recent thread revival is the QED 360 spec cams in a standard but fuel injection equipped twink is a pretty good bet.
Paul
pauljones
PostPost by: elj221c » Mon Nov 11, 2013 5:00 pm
QED specs here:-
img017.jpg and
For interest i have added a couple of pages from my '75 notebook. Obviously the QED notes in red were added later, about nine years ago.
img018.jpg and
Roy
'65 S2
elj221c
PostPost by: john.p.clegg » Mon Nov 11, 2013 9:36 pm
Roy
Yours differs from what they are putting out now (MOPs of 100,106 ) as opposed to 105,110..
Jets etc...
as for the second sheets I have downloaded them but can't make them out...
John :wink:
Q420 (1).pdf
(261.1 KiB) Downloaded 1659 times
PostPost by: elj221c » Tue Nov 12, 2013 8:52 am
john.p.clegg wrote:Roy
John :wink:
For me I just click on the image and it magnifies.
Or is it my scribble that you can't read? :oops:
It was just for interest. I wouldn't rely on it, especially the likes of the machining to be done on the spring pockets (first page far right in red). I seem to have two dimensions for the L1 and L2 lift as well???
Roy
'65 S2
elj221c
PostPost by: john.p.clegg » Tue Nov 12, 2013 10:52 am
Let's just put it down to my age and tired eyes late at night...things look so much better this morning (in the light of day)..
John :wink:
Previous
Users browsing this forum: jdouglas300 and 38 guests
