Engine block numbers
PostPost by: ardee_selby » Tue Oct 23, 2012 1:05 pm
piss-ant wrote:OK, I was not there and I do not know.
This whole subject is very frustrating for me!
I was there (Ford Thames Foundry Dagenham) on and off over a 5 year period. It was a long time ago and memory fades. Also my focus was on the plant engineering & manufacturing processes (blast furnace, coke ovens, foundry...cupolas, moulding lines, core blowers etc etc) not product engineering per se.
I do, however, know that some folks interpretations are way off the mark. In other words I can help with what things aren't...but not necessarily what they are! :roll:
Later....
Cheers - Richard
ardee_selby
PostPost by: garyeanderson » Tue Oct 23, 2012 3:21 pm
Later....
Cheers - Richard
So clue me in on what is wrong with what I have said. That way I won't repeat it and be wrong again and again.
Gary
garyeanderson
PostPost by: bigvalvehead » Tue Oct 23, 2012 6:59 pm
I have 2 L blocks both on std Cortina bore size.
One has the "normal" thick L and the other a thin L.
Until I picked up on this thread i had never seen or heard of the thin L
I'll check some numbers tomorrow
Dave
Dave Hughes
S2 26R
Elan DHC Sprint
bigvalvehead
PostPost by: LCRJ » Wed Oct 24, 2012 4:38 pm
Hi all,
I?m reading your contribution very interestingly.
The T number must be the group of core patterns of the raw cast iron part.
I?ve seen T20 max. also I found the T number in the cast iron gear box(T4) too.
The Alloy parts cannot find the T number.
I think that there is no correlativity in the T number and thickness.
If it has correlativity, Lotus Block will surely be the always same or close T number.
The suitable as a method of the thickness, it is a stamping grade "LA" or "LAA" rather than a casting T number.
I?ve never seen the skinny "L". Isn't it only related to the date of block?
Let's investigate thoroughly!
Thank you,
Hiro :D
LCRJ
Previous
