Gasket set - Washers?
PostPost by: AHM » Sun Feb 19, 2012 1:59 pm
It looks like the smaller alloy washer could be for the oil pump to filter bowl bolt.
AHM
PostPost by: AHM » Sun Feb 19, 2012 4:17 pm
ardee_selby wrote:
AHM wrote:
elanman999 wrote:The thick alloy washer is for the chain tension pivot bolt.
That's what I thought, but it is too small. I will post a picture. Thanks,
Simon
This it?
The attachment Washer.jpg is no longer available
That must be a typo if the plug 9) is 1/4 bsp so 8) 3/4 bsp washer ...might not seal. It is probably copied from 7) 3/4" expansion plug
Below is a picture - looking for a home for the larger copper crush washer.
Shown are the sump plug and filter bowl bolt.
Washers.jpg and
AHM
PostPost by: AHM » Mon Feb 27, 2012 12:21 pm
update...
I was just abot to throw the box (Payen EF881) away and notice that it lists contents on the front.. :oops: Oops! Well it was face down with gaskets in it.
Distributor to block (O-ring)
Oil Filter bolt ( Small Alloy washer)
Sump Drain Plug (Small Copper)
and wait for it...
Fuel Lift Pum Bowl - Looks like Gary was right!
The Large Copper and alloy washers must have been from other kits.
Simon
AHM
PostPost by: ardee_selby » Mon Feb 27, 2012 12:39 pm
AHM wrote:update...
So as per this set, then.
http://www.ebay.co.uk/itm/LOTUS-FORD-TW ... 0478680021
This set (question mark).jpg and
Is the petrol pump "gasket" impregnated to turn it into a "seal" for immersion in fuel?
Cheers - Richard
ardee_selby
PostPost by: oldelanman » Mon Feb 27, 2012 12:45 pm
AHM wrote:Fuel Lift Pum Bowl - Looks like Gary was right!
Well done Gary......I stand corrected ! Should never have doubted your memory.
S4 DHC
PostPost by: garyeanderson » Mon Feb 27, 2012 2:16 pm
Hi Roger
I am old and I do forget, remember things that are not always the way it was, and other forms of mind misrepresentation. Its been a long time since taking things apart and some things just seem like they were not important in the heat of taking things apart. I didn't have a camera early on and when I got one the simple things seem so simple why would I waste a dollar or what ever to get a photo that I would loose? Don Tingle was the person I believe that pointed out that the fuel pump bowl gasket and the oil cap gasket were the same and used interchangeably (I think :) ) .
I have dug out all of the brake hard lines and am having a dejavu of What the fuc% was that from moment. At least 6 or 7 Elan chassis and some Cortina tossed into the mix, RHD, LHD dual boosters, Single boosters no boosters. So far I Identified the right front caliper to 4/5 way union Right rear caliper to 3 way union and the front 4/ 5 way union to rear 3 way union. The 4/5 way union to left front caliper.I have one rusty Left rear caliper hard line to 3 way union and then there are all of those lines that I never used that are from the master to the booster or duel master to dual boosters, LHD and RHD , THe RHD should be easy as its only a single booster. I will get a photo but I need to go across town to my trailer to see if I can add to the confusion... :D
Got to keep you folks laughing you know.
garyeanderson
Previous
