Aluminum Oil Pan Poll
Aluminum Oil Pan Pole
Poll ended at Thu Dec 15, 2011 8:05 pm
1. I have no desire to buy an Aluminum pan at any price.
41
59%
2. I would be willing to pay as much as $300 US dollars.
10
14%
3. I would be willing to pay as much as $350 US dollars.
9
13%
4. I would be willing to pay as much as $400 US dollars.
1
1%
5. I would be willing to pay a max of $500 US dollars.
8
12%
Total votes : 69
PostPost by: Tahoe » Tue Dec 13, 2011 3:45 pm
Bump, incase anyone else wants to vote. Voting ends this Thursday.
Thanks to everyone who has taken the time to vote so far, it's been very helpfull. Not much will happen with this project until after New Years. I'll start another thread IF this is a go.
Tahoe
PostPost by: Rob_LaMoreaux » Wed Dec 14, 2011 4:32 pm
Baffling would be a must since the biggest issue I have with the stock sump is uncovering the pickup on right hand corners. Maybe Design in a pickup?
More oil volume isn't really necessary if the pickup does not come uncovered.
Also an aluminum dry sump can be had new for between $700 and $900 plus the pump etc. Cheaper used if you find someone who used to race Formula Ford.
A sump guard really isn't needed like it is for an Alfa. With an Alfa the first thing to hit is the sump, where on the Elan the first would be the frame crossmember. Also on the Alfa the sump is in front of the wheels to it gets close on a steep approach, where the Elan the sump is behind the wheels so it doesn't have approach angle concerns. Yes, my Wife's lowered Alfa Berlina has a sump guard and it hits regularly, where the Elan only ticks the tip of the supertrapp muffler.
Rob
Rob_LaMoreaux
PostPost by: mrob » Wed Dec 14, 2011 7:54 pm
Rob_LaMoreaux wrote:Baffling would be a must since the biggest issue I have with the stock sump is uncovering the pickup on right hand corners. Maybe Design in a pickup?
Has anyone had experience with the "Real Swinger" oil pickup system that was sold by Dave Bean?
Michael Robertson
64 Elan S1
mrob
First Gear
First Gear
PostPost by: stugilmour » Thu Dec 15, 2011 1:47 am
Thanks for that Rob. I couldn't recall who here owned the Berlina. I had forgotten about the positioning of the engine; mine was a Berlina as well with sump guard, although I don't recall grounding being a frequent issue.
Thinking it over and being under the car fiddling with the starter motor I am also less convinced of the need for additional oil capacity. The clearances to the frame, header down pipe, & starter look like a hassle (as also mentioned by Rohan), let alone the desire to perhaps keep the component more universal. I was originally thinking of the added oil capacity in terms of extended intervals to checking the level; I suppose if the component solves the leaking issue the actual oil consumption may be quite modest. :) I would sure not want Russ to abandon the project due to difficulties with re-design if a stock shape pan was feasible.
Stu
1969 Plus 2 Federal LHD
PostPost by: StressCraxx » Thu Dec 15, 2011 4:06 am
Rob
Rob,
I agree about keeping the pickup covered. I am not sure that increasing the size of the sump is the answer. The early ropeseal pan with the bell pickup in the center of the sump did not run dry as easily. The lipseal pan put the pickup tube on the right side of the pan, with the oil going up the side of the pan and block in hard right handers.
There are some trap door baffles and scrapers to reduce windage available. The scrapers are cheap horsepower too. Modern road cars use some very sophisticated windage trays and scrapers to reduce the pumping losses of oil flailing around the crankcase.
http://www.crank-scrapers.com/Ford_Kent.html
StressCraxx
PostPost by: Foxie » Thu Dec 15, 2011 8:53 pm
elancoupe wrote:60 reads and 8 voters? If you take the time to read the topic, place a vote!
I don't seem to be able find the "vote" option here.
However, I have cracked the original aluminium sumps on both my BMW 323s, both which disintegrated on the spot, risking a wrecked engine, and causing inconvenience and expense, not to mention the pollution. They have been replaced with steel sumps.
I have a QED baffled, large capacity steel sump on the twincam, which has survived many a grounding. With the oil cooler, I have more than enough capacity.
Just my experience :D
68 Elan +2, 70 Elan +2s
PostPost by: Famous Frank » Mon Dec 26, 2011 2:25 am
I vote for the cast pan (they just look cool) with an extra qt of capacity like Greg Z was talking about........ "T" pan. If it has extra baffling all the better. And I'd pay $350.
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank
PostPost by: tvacc » Tue Dec 27, 2011 6:29 pm
mrob wrote:
Rob_LaMoreaux wrote:Has anyone had experience with the "Real Swinger" oil pickup system that was sold by Dave Bean?
I have the swinger on my Elan. Works great.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc
PostPost by: Mazzini » Sun Jan 08, 2012 8:56 am
PostPost by: StressCraxx » Fri Feb 10, 2012 2:59 am
The cost of building the patterns is prohibitive for a cast sump. Now we can print a pan in thermoplastic. Will an aluminum printer be next?
http://news.yahoo.com/blogs/this-could-be-big-abc-news/machines-creating-machines-181919022.html
I can think of some cool things to make!
StressCraxx
PostPost by: sevenhead » Fri Feb 10, 2012 5:46 am
There are all levels of pattern manufacturing depending on quantity that are required.
The patterns could be made using the SLS (Selective Laser Sintering) process.
sevenhead
New-tral
PostPost by: Tahoe » Fri Feb 10, 2012 8:02 pm
Guys,
I haven't let this die yet and I will pick it up again when I can, however an unexpected hospital visit for my wife a month ago has not helped in the funding department. Shes fine now, but it's amazing how much a couple days in the hospital costs even with insurance. Anyway, it may be 6 months from now, but I'll update everyone again when I can.
Tahoe
PostPost by: StressCraxx » Sat Feb 11, 2012 3:57 am
Tahoe wrote:Guys,
Russ, no worries to you about this at all. Our prayers and best wishes to you and your wife.
Dan
StressCraxx
Previous
