Sparking plug torque
A drop of oil on the threads of each plug from the dipstick. Thread plugs in with fingers, torque to 20 lbs/ft. Torque specs from the Machinist's handbook tables are for oil lubricated threads. I have never stripped a spark plug hole in 48 years of car repair.
Never-seeze often seems to wind up where it should not be. Told my engine builder he wasn't going to get another flagon of rum if he ever did that again.
types26/36 wrote:.....using a torque wench to fit plugs (shaking head).....never have and never will .....OK! .....Yes..I know its in the manual..... Yar-de -Yar-de Yar.... what's wrong with you people ....don't you have sense of feel....flame away
I agree..
For the first time ever! I used a torque wrench on the plugs in the Elan, and lo and behold it sure felt way too tight, so I stopped short of full click on some. Even checked two torque wrenches against eachother. I am afraid to remove them now .
I was debating posting to see if the manual was incorrect.
Never had a plug leak, break, or seize when I did them by feel; back to the feel method for me!
re the anit sieze - Copper and aluminum are on opposite ends of the galvanic series, I realise not in salt water but, hmm should Cu be used?; notwithstanding the copper head gasket surface
Jack
- jk952
Users browsing this forum: pptom and 32 guests
