help in installing an oil pressure warning light....
PostPost by: neilsjuke » Mon Nov 23, 2009 10:21 pm
You can get adjustable pressure s/w if you oil preasure is a bit low at tick over or look at it from the point of view that it's better to know it is working ,always had one on my rally cars
Neil
neilsjuke
PostPost by: bcmc33 » Tue Nov 24, 2009 1:07 pm
bcmc33 wrote:All you need to fit an oil pressure sensor is a suitable 1/8? BSP tee piece and a sensor
Ignorance is bliss as my old mum used to say. :oops: This, of course, should have read 1/4" BSP :oops:
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: gordont » Wed Nov 25, 2009 11:23 am
thanks all, off to look at the necessary connections so I can wire it in..
Gordon
26/5416
gordont
PostPost by: bcmc33 » Wed Nov 25, 2009 12:40 pm
neilsjuke wrote:I use a 18 psi switchNeil
Neil,
From where did you get the 18 psi switch?
I'm now wondering what value switch is best. Most of those advertised appear to be 5 psi, but I found one Ford RS switch at 25 psi which for the Twink may be a little on the high side.
All advice welcome.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: neilsjuke » Wed Nov 25, 2009 3:12 pm
From my stock of bits from the 70s
http://www.thinkauto.com/acatalog/On_li ... es_34.html
Think have some 20 psi and adjustable to 15psi above
http://www.demon-tweeks.co.uk/products/ ... ode=LMA014
Neil
neilsjuke
Previous
