How far can you go without a belt?
PostPost by: bill308 » Fri Jun 20, 2008 10:44 pm
My read on this is that you were exceeding lucky. It may be that no damage occured.
I'd change the oil and retorque the head and drive it for a couple of weeks, then recheck the head torque.
If all is well after this, then I think you are good to go. The only expense is maybe a valve cover gasket.
If the head bolts loose torque and there is evidence of plastic deformation under them, I might then try some slightly oversize, hardened, head bolt washers and give it another go. I don't see what you have to loose at this point.
Bill
bill308
PostPost by: blackandgold » Tue Jun 24, 2008 7:20 am
Bad luck with the car
Hope the Leonard Cohen concert was worth it, I am a big fan of his music where was he playing?
Lets hope the sisters of mercy are smiling on you and there is no serious damage
1973 +2 S130 with BDA
blackandgold
PostPost by: dgently » Tue Jun 24, 2008 11:39 pm
L. Cohen concert (outdoor, in pouring Dublin rain) was, against all odds, one of the most uplifting and impressive I've ever attended. Catch him if you can - he's well into his seventies but can put on a show with the best of them.
I have only now got around to replacing the belt and trying it. It started and ran normally. Haven't retorqued the bolts, will do that before putting it back into use.
I don't think I'm out of the woods though. A gentle fast metallic rattle towards the front sounds like (water pump?) bearings and I could swear I can hear air leak around the front carb.
Thanks again for all the advice, I'll update when I know more.
dgently
Previous
Users browsing this forum: No registered users and 72 guests
