Pulling my hair out! Why is my Elan so down on power?
PostPost by: M.J.S » Sat Jun 14, 2008 9:33 am
Thanks to everyone for all you replies.
Will bite the bullet tonight, redo the compressions as suggested, and take the cam cover off to check on the timing.
Fingers crossed. I hope that's what it is. If not then I think the head will have to come off for a study of the valves and bores.
Will post again after I've had a peek and report back.
Mark.
M.J.S
PostPost by: Craig Elliott » Sat Jun 14, 2008 10:35 am
One other thing to check, is the fuel pump ok?
Assuming you've been doing the compression checks with the engine warm, throttles open etc they are low so the points about timing etc are right - unless it's so coked up the valves aren't seating properly??
C
Craig Elliott
PostPost by: M.J.S » Sat Jun 14, 2008 11:16 am
Craig Elliott wrote: unless it's so coked up the valves aren't seating properly??
C
Hi Craig,
I assume the fuel pump is OK. From looking through the transparent filter it seems to be pumping well enough.
As for being coked up, this is a concern. For the last few years the car was run once a week around the block for a couple of miles, and the owner would give it a bit of choke to start :shock:
When I bought it the plugs would coke up within minutes and you would have to take them out and clean them to get 4 cylinders back. ADjusting the mixture, a new set of plugs and never touching the choke cured that problem.
It could be the valves are badly coked up, hence the compressions. I'll check out the timing marks but it's looking like the head will have to come off. I'll have to have a stiff drink before I look :)
Mark.
M.J.S
PostPost by: Craig Elliott » Sat Jun 14, 2008 5:33 pm
Good luck! Checking that the timing chain hasn't jumped is pretty straightforward - assuming you've got the workshop manual.
As you say it would seem odd that the compressions are so uniform if you've got bent valves. Not sure how you'd check how badly coked up it is without removing the head - may be worth having a quick look at the tops of the pistons by taking the plugs out and shining a torch in...
C
Craig Elliott
PostPost by: pauljones » Sat Jun 14, 2008 6:26 pm
have you checked the dizzy is working and advancing ok,i ask this because my dad had a car with similar problems years ago.if my memory is correct it was mechanical advance and would only run when up to temperature.i think the cure was simply a strip down,spray oil and wipe dry,then put back together,new points ect and job done.later an up rated coil was added,but i think that was because it was spare from a rebuilt jag v12. could it be the advance mech is stuck some how?
pauljones
PostPost by: denicholls2 » Wed Jun 18, 2008 10:24 pm
But I also second spark advance as a possible culprit with a simple fix. Your symptoms suggest a poor advance curve.
You do need to have the throttles open when doing a compression check. My guess is you didn't, else your compression is indeed poor.
This engine isn't broken in yet based on mileage from rebuild, so expect more power and fuel economy when it is. But something is wrong besides that.
denicholls2
PostPost by: tawnyowl » Fri Jun 20, 2008 11:24 pm
I had a similar problem once which took months to resolve as it was so deceptively obscure. The symptoms were the same, everything Ok until you want some power then it dies.
The problem was fuel starvation and was caused by flakes of rust from the inside of the fuel tank coagulating in the bottom of the fuel tank and partially blocking the outlet pipe.
To check/clear syphon the petrol from the tank and then undo the banjo thingy below the tank and clear all the stuff out.
Tawny
tawnyowl
New-tral
PostPost by: tawnyowl » Fri Jun 20, 2008 11:33 pm
Tawny
tawnyowl
New-tral
Previous
Users browsing this forum: No registered users and 56 guests
