Plug Failure, or Bottom End trouble ?
PostPost by: SADLOTUS » Mon Jul 07, 2008 10:35 am
Hi Richard, first of all - bad luck.
Try taking a trip up to Baldynes at the rear of the airfeild at Biggin Hill, last time I went he said he had a few twincam blocks heads and bits aquired over the years and was saving them for his pension. It's a real mess up there and be prepared to hang around a while chatting, but you may come away lucky.
Through a couple of lift up gates and all the way round to the back past the WW2 shelters/bunkers just before the helicopters, you can't miss it... Tatras, Skylines and all sorts up there!
ttfn
Paul
SADLOTUS
PostPost by: rgh0 » Mon Jul 07, 2008 11:21 am
Complete twin cams come up on Ebay in the Uk regularly. Going price seems to be from 1000 to 1500 pounds depending on claimed condition. I would bet almost all will need a rebuild so really what your looking for is one to rebuild that has no major head or block faults.
After you build a good engine from the best bits of the two engines plus anything new you need you can probably sell of the remaining bits such as front water pump cover, sump, cam cover etc for a few hundred pounds. You should be able to get something for your damaged head as well as there are enough people out there who will take on the repair challenge.
hope you get it fixed and back on the road soon
PostPost by: neilsjuke » Tue Jul 08, 2008 12:04 pm
Hi Richard yes I would go and see Dave at Baldyne 01959 540206 they have been around for a long time and do not BS could the block be linered/ head welded, See you if your going to Naff Kent on Weds
Neil
neilsjuke
PostPost by: tdafforn » Tue Jul 08, 2008 12:22 pm
Another option is to go for the 711m block conversion.
these blocks come up on ebay for much less than a trad. twink block..
I picked a full crossflow engine up for <?100..
Then all you need are spacers for the timing chest and breather and a longer chain..
The added advantage of this approach is that you can use standard pistons (available for ?60 a set!)
tim
tdafforn
PostPost by: tdafforn » Tue Jul 08, 2008 1:32 pm
tim
tdafforn
Previous
Users browsing this forum: No registered users and 73 guests
