Q420 cams ...
Old English White wrote:john.p.clegg wrote:And as for the timing, the spec sheet states I/L 105 ATDC E/X 110 BTDC
John , Rohan ,
Here are the data sheet I get with the cams ...
John , your's is a bit different , isn't it !?!
Rohan , does this help !?! My head is an early type , staying with Weber's 40DCOE , and it had been already ported ...
I just can't read anything about valve spring pocket ...
Christian.
Here is the other data
Client: JOHN FORD
135BHP
Vehicle: LOTUS ELAN Vehicle Reg.: TWH849K
Engine Spec.: QED420CAMS
Reference Run: 22 July 2014 10:10:37 0.0 degC 0.0 mbar 0.0 %RH Correction Factor:0
Speed RPM Corr. Power Torque Tractive Force Power(raw) Lambda In 2
32.4 2001.0 13.5 35.5 160.6 13.9 0.0 0.0
48.7 3004.0 52.6 92.0 416.3 54.0 0.0 0.0
64.9 4006.0 70.9 93.0 420.9 72.8 0.0 0.0
81.1 5004.0 89.4 93.8 424.3 91.7 0.0 0.0
89.4 5517.0 98.5 93.7 423.9 101.0 0.0 0.0
93.4 5767.0 95.2 86.7 392.0 97.6 0.0 0.0
Run 1: 22 July 2014 01:28:33 30.7 degC 1020.3 mbar 53.1 %RH Correction Factor:0.9759803
32.5 2003.0 24.2 63.6 287.1 24.8 0.0 0.0
48.7 3008.0 53.0 92.5 417.8 54.3 0.0 0.0
64.9 4007.0 73.3 96.1 433.9 75.1 0.0 0.0
81.1 5008.0 91.7 96.2 434.2 93.9 0.0 0.0
89.3 5509.0 99.2 94.5 426.9 101.6 0.0 0.0
93.4 5767.0 98.5 89.7 405.0 100.9 0.0 0.0
97.3 6003.0 100.4 87.9 396.7 102.9 0.0 0.0
Run 2: 22 July 2014 01:46:44 30.8 degC 1019.9 mbar 51.0 %RH Correction Factor:0.9765176
32.6 2010.0 25.5 66.7 300.9 26.1 0.0 0.0
48.7 3007.0 52.2 91.2 411.6 53.5 0.0 0.0
65.0 4009.0 74.6 97.7 440.9 76.4 0.0 0.0
81.2 5014.0 97.9 102.6 462.9 100.3 0.0 0.0
89.4 5518.0 107.9 102.7 463.6 110.5 0.0 0.0
93.6 5776.0 108.5 98.7 445.4 111.1 0.0 0.0
97.2 6001.0 105.0 91.9 414.7 107.5 0.0 0.0
101.7 6275.0 105.7 88.5 399.3 108.2 0.0 0.0
Mosley's Rolling Road
The Old Creamery
Ffairfach
Llandeilo
Carms SA19 6UH
Tel. 01558-823368
mob.Mobile
email: [email protected]
EOF
Client: JOHN FORD
135BHP
The Old Creamery
Ffairfach
Llandeilo
Carms SA19 6UH
Tel. 01558-823368
mob.Mobile
EOF
You know you have a good car when your wife hates it.
Jon.ford - Second Gear
Hi John.
Thanks for posting the dyno results.
I assume the round markers are for horsepower. Is this correct?
I assume the squares are the corresponding markers for torque in lb-ft. Is this correct?
I assume the reference condition is before any tuning was started. Is this correct?
I assume all values are as measured at the rear wheels (i.e. not extrapolated to the engine flywheel). Is this correct?
Bill
Bill
- bill308
Users browsing this forum: Dan in NJ and 8 guests
