Headlight relays
PostPost by: Robbie693 » Tue Feb 05, 2008 9:48 am
handi_andi wrote:What I have done is to drive the relays directly from the feed that used to go to the headlights. There are two cables for both main beam and dipped that have bullet connectors on them in the nose cone. Hence you can jump a relay in there with the helpfully supplied ground as well if you want to. Also gives the benefit of there being a second feed available if one of them goes wrong, which has happened on mine. Although have to admit I can't remember where you are wanting to mount the relays so may not be that helpful sorry.
Andy
No, that's very helpful - just what I wanted to know.
I am mounting the relays in the nose so those bullet connectors will do nicely. Although I'll have to cut them off to attach spade terminals for the relays.
Thanks Andy
Robbie
Robbie693
PostPost by: handi_andi » Sun Feb 24, 2008 11:32 pm
As promised a while back some pictures of my nose cone relay and fuse box arrangement. Apologies for quality but not easy place to photograph let alone work in.
Andrew
DSCF0728.JPG and
Good picture of the use made of pre-punched galvanised steel strip and stainless steel bolts and nylocs to build the frame
DSCF0727.JPG and
Close up of the left hand lotus elise driving light, showing also how the frame attachs to the two original air filter mounting points and two spare holes in the front top flange of the nose cone
DSCF0726.JPG and
The discrete air filter upgrade
DSCF0725.JPG and
Lotus Elise bugeye driving light, which fit nicely but at the moment don't give much extra light. Mainly because the alternator is struggling, probbaly cos it is caked in engine oil at the moment. So it is going to be pulled soon and cleaned up and if tha
DSCF0724.JPG and
The relay on the right hand side at the back is actuated via the micro-switch and turns on the sidelights and rear lights when the headlight pods go up.
DSCF0723.JPG and
The complete arrangement. The two relays on the right power the halogen headlights, and the two on the left the fog and driving lights.
DSCF0722.JPG and
Auxilary fuse box to run nose cone electrical items, bar air horn compressor on the left. Air filter is bolted to frame and as another supporting piece of steel in its end as kept falling off.
handi_andi
PostPost by: bcmc33 » Mon Feb 25, 2008 12:19 am
I like the idea of the neat driving lights.
However, how are you going to convince the police that they are not fog lights when they want to fine you ?60 + 3 points for using them on non foggy nights?
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: handi_andi » Mon Feb 25, 2008 12:23 am
That's easy, as I have a set of fog lights as well in the normal place on the front nose cone. As lotus orginally had fog and spot lights then the spot lights, albeit in a modified position are still legal.
As it happens I did have a run in with the police about 9years ago over using my fog lights when it wasn't foggy but was nighttime. It was all I could do to stop yself pointing out it was dark when he asked my what visibility should they be used in.
Personally I like them as well as they are also a genuine lotus part! Unlike the fogs which are old Halford stock but look right, althoguh different from the originals.
Andrew
handi_andi
Previous
