properly sealed dipstick
PostPost by: Johnfm » Mon Oct 07, 2013 11:18 pm
Cheers Stu
I think the cam oil breather is OK - but have removed it to clean the gauze cone filter in there.
The breather pipe is a surprisingly loose fit into the head on my car.
I will probably buy a separate canister and plumb the oil breather there and by something to seal off the dipstick to check the source of the leaks.
1967 Plus 2 #0168
Johnfm
PostPost by: vernon.taylor » Tue Oct 08, 2013 6:46 am
Salut Stu
Good tip - you don't remember the diameter of plug you used ?
Merci
Vernon
vernon.taylor
PostPost by: oldelanman » Tue Oct 08, 2013 9:47 am
Thin wall heat shrink sleeving is another way to seal the dipstick and stop it rattling........makes it a snug push fit in the tube.
Dip stick seal 007.jpg and
S4 DHC
PostPost by: Galwaylotus » Tue Oct 08, 2013 10:13 am
Good idea! I'll try that. :D
'67 S3 SE FHC
Galwaylotus
PostPost by: oldelanman » Tue Oct 08, 2013 10:26 am
Should have mentioned also.....thoroughly clean the oil from the dipstick first and put a dab or two of superglue on it before you shrink the sleeve.
S4 DHC
PostPost by: Galwaylotus » Tue Oct 08, 2013 10:41 am
The first part goes without saying. I hadn't considered the super glue though. Thanks.
'67 S3 SE FHC
Galwaylotus
PostPost by: stugilmour » Tue Oct 08, 2013 4:39 pm
Great idea! Always a better mouse trap!
Stu
1969 Plus 2 Federal LHD
Previous
Users browsing this forum: phil1800 and 28 guests
