Inserting the dip stick tube into the Burton Front cover
HI, I had earlier initiated a post on the require exposed tube length which turns out to be 60 mm as confirmed by Colin also.
Now I have to insert the tube into the casting. Had not realized that part of the initial preparation of the parts for the Burton Water Pump conversion is inserting the tube before assembly by heating the casting in boiling water and then tapping in the tube which has been kept in a freezer until inserted.
I have the Burton castings on the engine now and have to insert the tube. Little nervous about heating up the casting. Any experience just taking the very cold tube and immediately tapping it into the tube hole without heating the surrounding area? Does that work?
- EricB
Hi again Eric,
I inserted the tube before fitting the front cover. However, I fine tuned the depth of the tube, after filling the engine with the required amount of oil, by inserting a screw driver into the tube and tapping it down gently cold.
The tube supplied with the kit was copper. I believe, that there may be tubes made of a different material, so can’t comment on the ease of tapping it in when at room temperature.
Think you would be okay gently heating the area of the front cover with a heat gun, and/or cooling the tube in the freezer beforehand.
Colin.
quote="EricB"]HI, I had earlier initiated a post on the require exposed tube length which turns out to be 60 mm as confirmed by Colin also.
I have the Burton castings on the engine now and have to insert the tube. Little nervous about heating up the casting. Any experience just taking the very cold tube and immediately tapping it into the tube hole without heating the surrounding area? Does that work?[/quote]
Colin.
'68 S4 DHC
- fatboyoz
I suggest you polish the tube and make sure there is a chamfer on the end. The tube should be steel. Use a bolt/screw in end of tube to drift into casting.
- alan.barker
