+15 piston rings
Rebuilding an S2 engine, thats been bored in the past to +15 and it came with got a very good set of +15 pistons, struggling to find new rings to fit. Have tried the usual suspects. Any thoughts? or has anyone got a set they’d be willing to part with. Have been told could successfully mod +20 rings as a plan B ...Thanks, Pete
- lottex
Try here https://www.fwthornton.co.uk
No problem in fitting +20 you need to re-gap to spec, from memory it’s about 0.006 – 0.009 place ring in bore use piston to ensure square in bore and use feeler gauge to set gap you will need a stone ideal Dremel, very hard and brittle material. Quite a long Job 4 pistons 3 rings.
- Craven
