Early engine numbers
PostPost by: dunclentdr » Sat Jan 07, 2017 4:32 pm
My S1 came with a 120E 6015 engine block stamped number LP0455 - I am not sure of the early engines had 3 or 4 numbers on the stamp i.e. if this was actually an early block would it be LP455 rather than LP0455?
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
dunclentdr
PostPost by: Elanintheforest » Sat Jan 07, 2017 10:17 pm
The heads were certainly stamped with 3 digits numeric David. I have LP189 and a photo of LP008, and that's how they are stamped. I'm pretty sure that the block stamp has the 4 digits numeric though. I'm sure someone else on here will confirm.
lp008-4.jpg and
lp189-3.jpg and
PostPost by: dunclentdr » Sun Jan 08, 2017 12:02 pm
Thanks Mark - yes, it is the number on the block I am checking - there is an engine with the 'flared' S1 I bought, head is a later high compression big valve one but if the block is a nice early stamped one I may keep hold of it, grateful if anyone can confirm whether low number blocks like 455 had four digits i.e. started with a zero.
David
David Rose
1965 S2
1966 S3
dunclentdr
PostPost by: dunclentdr » Sun Jan 08, 2017 2:43 pm
...here is the stamping...
img_2858.jpg and
David Rose
1965 S2
1966 S3
dunclentdr
PostPost by: jonsered 11 » Sun Jan 08, 2017 4:54 pm
Hi David,
both my early blocks are stamped LP followed by only 3 digits, matching the original buff log books, not sure why yours start with a zero?
Jonsered
jonsered 11
PostPost by: dunclentdr » Sun Jan 08, 2017 7:11 pm
Thanks - I posted originally because for some reason I thought it may have been stamped at a later point, party because there is no 'LBA' at the end.
David
David Rose
1965 S2
1966 S3
dunclentdr
PostPost by: rgh0 » Sun Jan 08, 2017 7:28 pm
Numbers on the later blocks at least were larger and not so deeply stamped and the surface they were on was rough casting. What style was used on the early blocks ?
PostPost by: Mazzini » Sun Jan 08, 2017 8:27 pm
rgh0 wrote:Numbers on the later blocks at least were larger and not so deeply stamped and the surface they were on was rough casting. What style was used on the early blocks ?
My '65 S2 has a larger and different style of numbers and letters.
PostPost by: LotusArchives » Sun Jan 08, 2017 8:29 pm
That engine number stamping doesn't look right
LotusArchives
