Camshaft question
Having purchased my Elan S3 SE with engine modifications from a previous owner, I want to try and determine as much as I can about what's inside the motor. The car pulls quite strong up to 6500 rpm. After pulling off the cam cover I expected to see the single groove camshaft fitted as standard to SE models. Instead it looks like the original S1 S2 camshaft (no grooves). I decided to investigate further to see if the cams were reground.
What I found was camshaft lift of .374" and markings on both cams - KH2. See picture below. Is anyone familiar with this camshaft? From the timing marks it appears the exhaust cam is advanced a bit. There is a notch next to the dowel on the exhaust sprocket. Is this what an offset dowel looks like? See picture. Help appreciated as usual.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
elancoupe
Thanks very much the quick response. I looked up the 112 in the Bean catalog and typically it provides about 135 HP when built properly. Much appreciated!
67 Elan +2
67 Elan +2
- seniorchristo
