Strange Motor Noise
PostPost by: fdk » Sun Oct 24, 2010 8:17 pm
I've bought very recently a Lotus Elan Plus 2 130/5.
I think that the motor produces a strange inhalation noise. You can hear it here : http://www.youtube.com/watch?v=LvOuzZXMonw
What do you think it could be?
(I have not synchronise the carburators yet)
Thank you, and forgive me for my english, I'm French (nobody's perfect).
Fran?ois
Lotus Elan Plus 2.jpg and
1973 Lotus Elan Plus 2 130/5
1973 Triumph Stag
1955 Triumph TR2
fdk
New-tral
PostPost by: Frank Howard » Sun Oct 24, 2010 9:21 pm
Francois,
Nice looking +2. It's difficult to tell by the video (audio?), but it could be a vacuum leak. First, I would get a fire extinguisher and have it handy. Then, I would spray starting fluid around the intake manifold but I would be careful as the starting fluid obviously is flammable and explosive. If the idle speed changes when you spray the fluid on a certain part, you've found your leak. Best of luck.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: Baggy2 » Sun Oct 24, 2010 9:34 pm
As Frank said it sounds like something sucking where it should not. I dont know if you are aware but the carburettors are flexibly mounted with rubber 'O' rings between the carbs and the manifold. If one of those was out of place you may get the sound recorded. For diagnosis I would use a piece of tube as a stethascope and move it around the engine until you find the exact location of the noise.
Its a great looking car - what colour is it and what type of wheels are they?
Baggy
Baggy2
PostPost by: hartley hare » Sun Oct 24, 2010 9:50 pm
hi there,have watched video,
has this just developed,or was it doing it when you bought car?
sounds consistent with engine tickover...hope it isnt, but could be a inlet valve seating problem..
suggest doing a compression test/valve clearance check...
good luck...
hartley hare
PostPost by: fdk » Mon Oct 25, 2010 7:20 am
Thank you everybody for your help.
The engine was doing this noise when I bought it.
I will check what you explained when my mechanic will come back from holiday, in one week or so.
@Baggy : the color is regency red, and the wheels are the original one, but they are painted in aluminium color, without the black color at the center as they should do.
1973 Triumph Stag
1955 Triumph TR2
fdk
New-tral
PostPost by: terryp » Mon Oct 25, 2010 4:10 pm
Fran?ois
Welcome to Lotuselan.net!
Bon Courage!!!!
Terry
terryp
PostPost by: fdk » Mon Oct 25, 2010 5:30 pm
Thank you Terry ;-)
Fran?ois
1973 Triumph Stag
1955 Triumph TR2
fdk
New-tral
PostPost by: peterako » Tue Oct 26, 2010 2:00 pm
Hi Fran?ois,
Lovely looking +2!
Another thought.
That sound is like the sound I can get when the choke (cold start circuit) is open on my Dell'Orto carbs.
I see you have Webbers but have you checked that the choke is closed?
Best of luck,
Peter
Terry....looks like the plan to have all the +2's relocate to France is working :)
'73 +2S 130/5
peterako
PostPost by: elansprint » Tue Oct 26, 2010 3:07 pm
Francois check it is not leaking around the headlamp vaccuum take off on no.1 cylinder inlet manifold. Good luck hope it is not something expensive & enjoy your new toy
Ian
elansprint
PostPost by: terryp » Tue Oct 26, 2010 4:07 pm
peterako wrote:Terry....looks like the plan to have all the +2's relocate to France is working :)
Peter
Its all in my plan for world +2 domination ......my plan is to have every +2 in France before 2020!!!!
Hope all is well
Terry
terryp
PostPost by: fdk » Tue Oct 26, 2010 4:40 pm
@ peterako : i've just verified. When I pull on the choke cable I can distinctively hear the aspiration noice of the carbs.
But the noise seems to come from the cylinder head, in front (radiator side). But my competence in mechanics are not enough for me to check more over. I will wait for the return of my mechanic next week.
I hope there is nothing to bad...
I will check the carbs (and the choke), the valves, and so on.
I'll keep you informed!
1973 Triumph Stag
1955 Triumph TR2
fdk
New-tral
PostPost by: fdk » Tue Oct 26, 2010 4:56 pm
Here is a new video I recorded, making variation in running speed of the engine.
http://www.youtube.com/watch?v=N48YX_2_c9Q
1973 Triumph Stag
1955 Triumph TR2
fdk
New-tral
PostPost by: terryp » Wed Oct 27, 2010 8:06 am
Fran?ois
I think the valve clearances are the thing to check
Good Luck / Bon Courage
A+
Terry
terryp
PostPost by: ecamiel » Fri Oct 29, 2010 2:10 pm
sounds like a loose spark plug? missing spark plug ring?
Eric
64 S1
ecamiel
PostPost by: JJDraper » Sat Oct 30, 2010 7:08 am
Synchronise the carbs. This sounds like seriously out of synch intake noise. The rest of the engine sounds mechanically good. 30 seconds with a screwdriver.
Jeremy
Next
