Which Magnecor KV85 set for the Big valve??
PostPost by: thor » Fri Jan 20, 2006 8:45 am
I''ve got a 1973 +2S130/5, with Lumenition and a sports coil, with some standard looking blue ignition leads. The coil looks to be in the original silly position too close the carbs.
I had a phone conversation with magnecor UK yesterday and I'm none the wiser. I've had the KV85 Competition silicon ignition leads from Magneor before and they're great. Can anyone help me out with what set I need, as they were asking about the distributor cap and the way the leads are connected here etc., and I can't get to the car at the moment,....
Thor Svaboe
1973 +2S130/5 white/silver
http://thorsvaboe.googlepages.com
thor
PostPost by: thor » Fri Jan 20, 2006 8:58 am
In the list on the Magnecor site there is ONE set for the +2, but 1967-72, which includes a DDB101 distributor cap to take the bigger 8-8.5mm cable. Is this the correct one for my '73?
Thor Svaboe
thor
PostPost by: Hamish Coutts » Fri Jan 20, 2006 12:27 pm
Thor,
I Phoned magnecor and ordered a set of leads and a new dissy cap for a twincam without any bother. They are blue in colour.
They look good and the car starts more readily. Have kept the standard coil and have 1970s lumenition fitted.
Car goes like a wee rocket. :D :D :D
Hamish.
Hamish Coutts
PostPost by: thor » Fri Jan 20, 2006 3:57 pm
So you reckon the set with the replacement cap will be correct, when it says +2 until '72 (the only set they have), there aren't any changes after that to the distributor that'll make this set not fit?
Thor Svaboe
thor
PostPost by: Hamish Coutts » Fri Jan 20, 2006 6:48 pm
Thor,
My car is a late 73 +2 S130 with a side entry Lucas dissy cap. The Magnecor stuff fitted fine.
Hamish.
Hamish Coutts
PostPost by: thor » Fri Jan 20, 2006 10:49 pm
Right, if no one has any other advice before mnday I'm trusting you and spending my ?65 on the lovely red silicone KV85 competition set with cap.. A good investment..
Thor Svaboe
thor
PostPost by: wildoliver » Mon Jan 23, 2006 10:09 pm
Take care, using a top entry cap will usually result in the leads/lead boots that connect the leads to the cap touching the aluminum (good conductor) inlet manifold, while there is no safety worries this can cause a slight misfire on occasion particularly if damp.
The twincams were meant to have a side exit lucas cap, with copper cored leads and screw in suppressed caps, I recently did this in mine, it cost approx ?25 inc cap, lead (bought by the metre and cut to fit) and caps, along with a pocket full of boots etc.
The result, a happy afternoon making them (I got all the parts at an autojumble all brand new although you can buy them from shops / internet if you dont mind paying more), a genuine period look, and having had the car rolling roaded at my local ford/twink specialist and set up properly 132 bhp at the wheels and approx 145 at the flywheel!
Just my advice! (being a tight yorkshire man!)
wildoliver
PostPost by: thor » Mon Jan 23, 2006 10:35 pm
the rather expensive kit from Magnecor actually includes a modified side entry cap, to take the lovely 8.5mm stainless core silicon plug leads which otherwise are too thick.. .. so I've been right in my assumption of correct dizzy cap then, which is good.
Thor Svaboe
thor
PostPost by: type26owner » Tue Jan 24, 2006 4:14 am
Please let me know if that cap has brass or better yet copper conductors. :wink:
type26owner
PostPost by: pereirac » Tue Jan 24, 2006 10:15 pm
I replaced my dizzy about 15 years ago (!) with a unit supplied by Aldon Automotive (I think it was a 45D4 unit). It's has a side entry screw on cap like the original unit but uses push on leads with brass ends rather than the ones which are fixed to the leads directly. I assume I would need a different lead kit?
Carl
pereirac
