S4 Electric Fan Choices
Hi All;
Looking to replace the missing pusher fan on my S4. I'm in the US.
Any suggestions on Electric fan types and sources to fit my Stanpart 10X22 radiator? Summit Racing carries several lines of fans that may work.
Rgds,
Phil Mitchell
Cupertino CA.
Rgds,
Phil Mitchell
Cupertino CA.
Phil
1968 S4/SE FHC 36-7936
- pamitchell
I just had the engine rebuilt in my 69 S4 and we used a fan from Dave Bean that connected to the front of the radiator with ty-wrap like straps. we connected it to the same power source as the ignition so it can only run when the engine is running and wired it through a cut-off switch - no thermostatic switch.
T I leave it on all the time when the engine is running. Cost was around $90.
Steve B.
Steve B.
Steve B.<br>1969 Elan S4
- poiuyt
I"ve had good luck with a Hayden fan from Pep Boys. Its a 10" pusher and I also purchased a variable electronic temp setting on/off switch from same. The wiring diagram was easy to follow which allowed me to wire in a manual override switch. I biased the fan to the right hand side (looking from the front) of the radiator to help push air along the headers and dissipate air out the cooling holes on the inner fender well.
Greg Z.
Greg Z.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Thanks for your suggestions! I have a 10 " Permacool fan and installation kit w/
adjustable temp module and temp probe coming from Summit Racing.
Phil
Phil
Phil
- pamitchell
I took the radiator down to a local shop and had them fit two 10" electric fans. Instead of using the tywrap things, I had them weld on a couple of brackets. I also had them weld in a bung for the thermostat probe on the control switch. I only have one of the fans wired in the second is "just in case" the first can't keep up in the summer
For installation pictures see <a href='http://www.unibrain.org/motorsports/elan/gallery/radiator' target='_blank'>http://www.unibrain.org/motorsports/elan/g...allery/radiator</a>
Unibrain - Third Gear
Jim, I like the idea of welding in a bung for the thermostat probe. My probe (get your mind out of the gutter please) goes between the fins of the radiator and although its pretty reliably consistent when it kicks on and off, I think yours is cleaner. I like the mounting brackets, too.
Greg Z.
'72 Sprint
Greg Z.
'72 Sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
If you do have a bung welded in, don't put it in the middle of the lower tank. It gets in the way of the bonnet spring. Guess how I know this. I ended up making a bracket to move the spring forward.
Hey Jim,
Ahhh... isn't the positioning of the temperature sensing fan switch kind of critical for thermal control reasons? By putting the switch in the bottom tank you've thermally isolated it from the water directly exiting the engine. One would expect you'll get some airflow cooling when in motion and some convective cooling when stationary and cause a time delay and temperature spike in the engine when experiencing a heatload event via excessive use of the happy pedal. Isn't directly downstream a short distance from the thermostat a better place for it to be located? That's where mine is. :ph34r:
Keith
Keith
- type26owner
You are correct, the better place would be nearest the upper radiator hose. If we wanted to be perfect engineers, a variable speed fan and a constant flow pump would be the way to go for optimal cooling. Practice suggests it doesn't matter much where the temp probe is since the fan only comes on when stationary or during slow city driving. While using the happy pedal the flow over the radiator is much greater than the fan generates so who cares if it turns on a little late. I've set the variable thermostat to come on just above the stable running temperature and am still tweaking on it.
Of course if I had a 170hp twink I'd be more concerned with optimal cooling.
Nope, that's old, obsolete technology. I'd do it with a heat pipe which has no moving parts. :rolleyes: Happen to be considering at the moment incorporating a miniature one for cooling down a sample to 4 degrees Kelvin. Fun stuff!
Keith
- type26owner
Hmmm... -452.5 F (forgive me I am rounding a bit here) might be overcooling your Elan a bit I think!
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
I fittied an Otter switch in the top tank of a Marston rad but made the mistake of putting it at the opposite end to the water inlet. I had to use an overide switch all the time when in traffic otherwis the engine would always run too hot. When it gets rebuilt I will have the position corrected. serk here I come!
Roy
'65 S2
Roy
'65 S2
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
Users browsing this forum: elanfan1 and 21 guests
