New Battery For +2s130
I have just got my +2 out of the garage with a view to finally finishing the restoration and making it a daily use car.
The first thing is the battery is dead. Any thoughts on the type and capacity of new battery I should buy? Or will anything do?
No doubt many more questions will follow!
- chrishewett
A battery will loose charge sitting on the bench for a period time. The battery might just need a charge. You can get a little tester to check the acid in the battery, some places will top up the acid for you.
Failing that buy a new battery. Not too sure about the capacity required but make sure you get one the right physical size as well.
steveww - Coveted Fifth Gear
I agree, check the battery water level, add if necessary and see if it can be brought back to life with a long slow trickle charge, if it's ok, put it in a Corolla and buy a new one for the Lotus unless it's a quick starting one..... I have an Optima battery in mine, it's been there through three or four Ohio winters and still works fine, lottsa cranking power and was in the car when I bought it. Not sure which exact model it is, the car's not here. I'll email you.
- 1964 S1
Replaced my battery the other month. Only problem I found was getting the correct type so that you could use the original mounting system. I tried charging the old battery, it would hold a charge but went flat when trying to start the engine from cold. The new battery has made a big difference to starting.
- JACKJABBA
What should the original mounting system be? Mine just sits in the boot. Obviously I will have to do something about it as I am likely to tip it over when cornering.
- chrishewett
The battery in my 69 +2 is the Optima 8000, 800 cold cranking amps which has gotten the job done a lot longer than I ever thought it would. I don't know how many years old it is but it's going strong. Made in the USA. It fits in the notch at the RF of my trunk/boot floor. Fits very snugly and I have immaturely never installed a hold down, figuring I'd have to flip the car to dislodge it but this thread has made me see the light. Mounting wise, I'll use a convential three piece unit, two threaded rods with J or T ends and an L bracket for the rear top edge of the battery. May have to strap between the T hooks underneath...
- 1964 S1
