Lotus Elan
Elan sprint wiring diagram
PostPost by: MACCA.GLM » Wed Nov 13, 2024 6:17 pm
Hi All
Does anyone have a elan sprint 1973 colour wiring diagram with alternator ,not control box I could download please.
G
MACCA.GLM
PostPost by: tonyabacus » Wed Nov 13, 2024 8:21 pm
G
Which harness, the front under the bonnet or the dash harness?
Tony
tonyabacus
PostPost by: MACCA.GLM » Wed Nov 13, 2024 8:57 pm
Front under bonnet please
G
MACCA.GLM
PostPost by: RichardS » Thu Nov 14, 2024 8:13 am
I use this one, from the Wiki section of the site (workshop manual - electrical)
https://lotuselan.net/w/images/4/4f/Ela ... wiring.pdf
I enlarged the various sections, and made A4 laminated sheets so you don’t need a magnifying glass!
I used the modified fuse layout which works very well
Lotus Elan Sprint FHC 1973
RichardS
PostPost by: tonyabacus » Thu Nov 14, 2024 10:34 am
Hello G
I agree with RichardS, I replaced my harness a short while back and found it pretty straight forward. I have for a long while also used the method of enlarging the diagram and laminating as it makes it much easier to read (especially for those of us with poorer eyesight).Besides being able to read a clean diagram with dirty hands and then wipe clean is worth the effort.
It is also a useful item then to pass on to the next owner. I also use the rear of the diagram to note any changes made (with suitable marker pen) as memory tends to fade over time and trying to recall changes can cause a bit of head scratching.
Another useful tip if the old harness is still in place, is to have the old and new harnesses in place so you can remove a wire and substitute the new wire which helps if you are unsure about following a diagram.
And of course there is always the forum members here to call on for help if necessary.
Let us know how you get on
Tony
tonyabacus
PostPost by: MACCA.GLM » Thu Nov 14, 2024 3:46 pm
I will print these off and use them
G
MACCA.GLM
PostPost by: Craven » Thu Nov 14, 2024 4:01 pm
Note, It does say Modified Harness.
PostPost by: MACCA.GLM » Thu Nov 14, 2024 4:07 pm
Yes I did notice but the drawings are much better than ive got so I'm sure will help
G
MACCA.GLM
